Question about Protron PLTV-4250 42 in. LCD Television
Protron 42 The TV is plugged in and there is no red light or green light - it's dead. I hit power and it does nothing. I have tried everyhing. from unplugging the power cord, trying other outlets., etc. I only bought this < 2 years ago!!! There were no power surges or anything. It is just dead, Please HELP!!! Thanks, Dawn
  • kubota58 Nov 01, 2008
    I had the same problem and that solution worked for me as well, and your right the switch is not obvious at first. Thank you for the info. kubota58
On the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Posted on Jul 10, 2008
I have a 32" Protron
The tv power supply board,that the board where the tv power a/c cord plug into it.U know basic electronic,have all the tools also can do soldering work too?Tries check the tv power supply board for dead components parts call capacitors parts,most of the times the capacitors parts are bulges ups or puffing ups onto it tops.These capacitors parts are dying or already dead.These capacitors parts are dead must to be replace.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 22, 2011 | Protron PLTV-32 Television
I have the protron 3750 the power light is red when i turned the power on the light turned green for a few second then turned red again and nothing happened. can you help?
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Protron PLTV-37 37 in. LCD Television
42 inch flat panel the tv will not turn on. The green light turns to yellow then red. The tv will not turn on. Its a Protron about 3 years old.
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help...
Jun 07, 2010 | Televison & Video
Protron PLTV 42 IN issue
I have had the same problem off and on since I purchased my protron 42" lcd. I have found that if I hold the power button to the tv a little longer, I rarely have the problem. Hope this helps.
Jan 22, 2009 | Protron PLTV-4250 42 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
My PROTRON LCD PLTV 32 IS BLACK & DEAD
LOOKING FOR A AC ADAPTIR MODEL :090-02180-13
Oct 03, 2008 | Protron PLTV-32 Television
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Protron PLTV-4250 42 in. LCD Television Logo
336 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
