Question about Mitsubishi WS-48413 48" Rear Projection HDTV-Ready Television
Caption I can't get the caption to turn off on my Mitsubishi WS-48413. I've gone in the menu and selected off for both analog and digital modes, but it's not changing anything. It's driving me nuts!
  • CCThompson Jul 12, 2008
    You were right! I called the cable company, and they walked me through going through the set up menu on the cable box to take the captions off. It was probably a signal that was sent from Comcast that turned it on, not my kids (which I originally thought)! :)
  • 51 Answers
Sometimes if you have a cable or satellite box as source.(if your case )then you would have to turn it off in the cable or satellite box.
Posted on Jul 10, 2008
How do I get closed captioning?
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
Mar 13, 2015 | Samsung 6350 Series UN65F6350 65" LED...
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
I can't get the closed caption off the screen
Closed caption can come from one of two places--either in the sets own menu---CC! etc or if you are using a box to provide signal to the set it can come from there.
Look first is the set's own menu---Closed caption is a option there.
If not selected in set menu call up box menu and look for it there.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
On certain channels, a black box apears, like picture in picture. will go away if i turn up the volume, but comes back,
You have some how turned on the closed caption (cc) either on the TV or cable box,first go into tv's menu under closed caption and select off,that should take care of it,if not try the cable box.
Mar 21, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Can't turn off captions on mitsubishi wd-62528!!
If you have the original remote it is in the Video Button Menu. Then select CC off, Or CC When muted.
This should work for you.
asnowman
Sep 19, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Close captioning stays on all the time.
if have remote or tv bo to menu scann threw it find captions and set off this may help
Mar 24, 2009 | Mitsubishi WS-55807 TV
Close captioning
Well lets try the simple things first, Go to the TVs menu using the original TV remote and find the icon or menu that says Captions, in that menu turn all the closed captions OFF. Second there is a button on the original TV remote that says format, push this till you get to a screen that says FULL in the upper left corner. That should resolve your problems, If closed caption still comes through then we need to know if this set is hooked directly to cable or goes through a cable box. It sound like you simply had the closed caption turned on and the screen in one of the zoom formats this TV provides
Mar 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Open Questions:
Mitsubishi WS-48413 48" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
