Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Debris around the motor shaft
I often have had to clean the "gunk" around the motor shaft where the belt fastens. There are times that the debris will get under the belt on the beater bar and actually cause the belt to rub on the sole plate.
  • 25 Answers
Remove sole plate then you can get to the belt
Posted on Sep 05, 2008
How can I get the brush roller to work
HI, it's Jim from Crucial Vacuum!
First things first, unplug your vacuum and turn it over. Check your brush roll for any large amount of debris. This usually comes in the form of carpet fibers, or hair strands wrapped around the brush roll. Try manually rotating the brush roll, this will help unclog any hidden debris.
Take off your vacuums bottom plate, this is usually held on by two screws on opposing sides of the bottom of your vacuum. Remove the brush roll and examine the belt to see if it is applying tension to the brush roll. If the belt is loose this would cause the brush roll to not work properly.
What's the quality of the bristles on the roll? If they look worn down, or loose then it's time to replace the brush roll itself.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Jan 28, 2015 | Vacuums
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
Brush not turnning
The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
Iv just replaced a motor in my vacuum with a brand new one but after 5 mins the shaft that the belt goes on to on the motor is getting very hot and the belt also it quite warm, could this be a faulty...
Sounds like the belt could be slipping causing friction. Try running without the belt just to eliminate the motor.If the shaft stays cool (as I am sure it will) try a new belt.there is a possibility that the brush that is being driven by the belt could be stiff with a build up of debris around the spindle.good idea to check this as well .
Sep 01, 2013 | Vacuums
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
MOTOR RUNNING BELT NOT BROKEN BUT DOES NOT PICK UP DIRT
you need to replace the brush and also the vaccum needs cleaning internally as it sounds like there might be blockage around the motor
Jul 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Drive belt ; whirlewind litespeed.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. lysager@gmail.com
Jan 25, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
47 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
