Question about Mitsubishi WS-65713 65" Rear Projection HDTV
Blinking green light
The ws - 65713 tv is blinking a green light and i pressed the reset button and it does nothing. need help please
  • 4 more comments
  • Anonymous Jul 21, 2008
    I have the same problem
  • cduma Jul 28, 2008
    same problem. just happened. Is it the light box that's blown and just needs replacement?
  • jasab21 Aug 05, 2008
    lately, every so often we go to turn the tv on and there is no
    picture. the solid green light starts blinking, stops blinking, and
    then startts again. After a long time, usually overnight, we go to turn
    the tv on and it works perfect.
  • albabane Aug 26, 2008
    basically ---"the blinking green light" . unplugging and waiting not working .
    resetting is not working .
    came back on after a couple days but now just the blinking green light
    read about the DM board and replacing capacitors where are these located ?
    how much does a TV man charge to replace these ?
    signed irritated
  • Anonymous Oct 12, 2008
    Green blinking light on ws-65713. after 1-2 days light goes off and works perfectly unitl 1-2 weeks later and repeats. fresno500@yahoo.com
  • John Howe Dec 23, 2008
    My email address is eaendeavors@gmail.com. Please send te instructions for locating and replacing these capacitors. Thanks!!
    Problem Solver:
  • 6 Answers
I had the same problem and just fixed it. You likely have 4 bad capacitors in your DM board. To fix you will have to take the DM board out of the TV, de-solder the ones on there and then solder on new capacitors. For those who would like instructions on this leave me your email and I will email them to you. I can't believe I was able to do this but thanks to Jaime for giving me the instructions and checking how to solder on Utube. No I had never soldered before guess it shows you can do it with some effort.
Posted on Nov 08, 2008
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
Green light won't stop flashing. Unable to turn off/on or reset.
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Green light blinking
Diane,
I do not have the service manual but have instructions with pictures. Will email them to you. If you have never soldered check look for instructions on utube and with some practice you will be able to de-solder and solder. A utube video that is great is at http://www.youtube.com/watch?v=I_NU2ruzyc4. Good luck.
Oct 06, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi TV WS-65713
mine is doing the same thing. It started when I unplugged it to move to a new location. Can some one please help me!!!!
Sep 19, 2008 | Televison & Video
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi TV
I thpught I sent this to you already?
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 23, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi WS-65713 65" Rear Projection HDTV Logo
238 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
