Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Won't go forward anymore
My Bissell gets stuck going forward...something keeps getting in the way, like the beater bar or something...I used to be able to fix it but not any more. Now all I can do is pull it backwards...ugh.
    President:
  • 1,673 Answers
Sounds like the half moon window and the clear noozle window have come apart. You may have to take one or the other off to re-align them. Sometimes you have to replace the half moon window, part # 2149851
Posted on Aug 10, 2008
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Smell of burning when turned on
Check to see if something is stuck in the beater bar, (aka- rotary brush). Might need a new belt.
Apr 21, 2014 | Bissell Vacuums
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
Vacuum extremely noisy
Mine is doing the same thing and my husband told me to purchase a new beater bar. I suggest you do the same.
May 26, 2010 | Bissell 6594 PowerForce Bagless Upright...
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Belt
Hi. This isn't a hard repair at all.... Unplug your vacuum. Turn the vacuum beater bar side up. Locate the catches or screws that hold the plate on that covers the beater bar. Remove the plate. The beater bar sits in sockets where it attaches to the vacuum, so remove carefully, making note how it comes out. This will make reassembly much easier. Place your new belt on the motor shaft, then onto the beater bar while you replace the beater bar back into the sockets. Test your work by revolving the beater bar a bit by hand. Reinstall the cover plate. That's it!
Regards! --W/D--
Jul 17, 2009 | Bissell 6594 PowerForce Bagless Upright...
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Not working
The bissell shampooers use belts t run the pump and the beater bar. if the master beltbroke which is the one that controls the pump and beater bar then yes the machine will not dispense water or turn the beater bar. it will have to be replaced *the belt that is*
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I smelled something like rubber abd now it won't pick up anything.
In all probabilty, your beater bar brush was jammed and the belt that drives it was stuck while the motor that drives it was spinning. This problem will manifest otself as a burnt drive belt. If you can open up the base part ( where the beater bar is) and examine that area for the drive belt..chances are you wil find the problem.. while there.. make sure your beater bar is free to rotate ( power should be removed or disabled while checking all this) Hope this helps...
Sep 21, 2008 | Bissell Vacuums
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
255 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
