Question about GE 74901 Clock Radio
GE Model 7-4966A Clock Radio
The bulb holder to display the time has broken and will not stay in place. As a result, we can not see the time on the clock. Where can I get a replacement bulb holder in the Syracuse, NY area?
  • Anonymous Dec 02, 2008
    I have te same problem, and am interested in a solution.
  • Anonymous Apr 20, 2009
    I have the same problem.
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Posted on Jul 27, 2009
SOURCE: Canceling the alarm
Disable the alarm permanently 1. Press CANCEL button. 2. The corresponding WAKE indicator will be flashing. 3. Press WAKE 1 or WAKE 2 button within 3 seconds to deactivate the corresponding alarm function permanently.
Posted on Jun 29, 2008
SOURCE: GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: I cannot set the time on my GE Spacemaker under
push the time button then set the time then push the time button a second time.
Posted on Sep 07, 2009
lock123
  • 6831 Answers
SOURCE: NEED A MANUAL
Hello
I found the manual that you were looking for. Just click on the link below and it wil direct you to the page where you can download the manual.
http://www.retrevo.com/s/GE+7-5290+Clock+Radio
Hope this can help you.
Best regards
Andrea
Posted on Oct 20, 2009
Need a bulb for a ge am\fm radio with cassette
Look in your phone book for places that sell bulbs.
Hardware stores, ect take the bulb in to be matched.
Nov 22, 2015 | GE Audio Players & Recorders
NO power to the radio or clock
Did you actually check the radio plug for power, or does the display just not illuminate? I ask because this radio has a little bulb inside that burns out that illuminates the clock, and radio station. You can confirm this by trying to use the radio normally, and trying to 'seek' a station. If you can get it to tune in, it is definitely the bulb. Another way is to shine a nice bright flashlight into the clock face. You should be able to see the stations and clock, that at least will tell you that the radio is working. - Hope this helps =)
Oct 05, 2015 | 1993 Ford Taurus
Set the cllock GE Model no 7-4801 A
To set the clock: 1. Press the SET button, the" : " will flash on the display 2. Press REV or FWD to set the time 3. AM or PM icon will show beside the time
The full manual can be found here, http://www.manualsonline.com/mdownloads/f8c57200-2d5f-c184-7944-ec02d8f9e065.pdf
Mar 15, 2011 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
How do I replace backlight on my bc895xlt
Greetings,
The bulbs can be replaced,
Remove covers taking care of the speaker wire. Remove screw for the green wire on disp. board and then the two screws holding the display board in place. Carefully remove the metal shield can with the four locking tabs. there are four grain of wheat lamps, two on each side of the display 12v/60mA DC. lamp # 7219 and radio shack sell them They are located in the white rubber holders on each side of the dissplay. unsolder the wires, pull up rubber white holder, remove bulbs, remove rubber light covers and put these on new lamps, slide lamp wires into rubber holders and then holders back to display pcb. Solder wires into place and repeat on other side of display. Usual common sence applies, be carefull, ect...,.
Apr 10, 2010 | Uniden BC895XLT Base Scanner
I'm having a hard time replacing the driver side headlight. Am I overthinking this?
Why are you trying to change the headlight? Is it broken?
If you are trying to change the bulb, because it is burned out, that is done from the rear of the housing. You have to exercise a bit of care getting the old bulb out and putting the new one in, but is it not difficult. If you are removing the right-side (from the driver's position) bulb, remove the battery (make sure you have your radio anti-theft code if you have one of those radios). Reach behind the headlight assembly, grasp the bulb holder retaining collar, turn it counterclockwise, then pull out the bulb/holder assembly. To remove the bulb from the holder, simply pull it straight out of the holder. Reverse procedure to lock the holder into place.
Removing the headlight housing is somewhat more involved. There are five bolts that hold it in place.
Sep 27, 2009 | 1993 Honda Accord
I have a GE Spacemaker digital radio, model 7-5295. What do I do to change the time?
  2. Use the TRK (SEARCH+TUNE) buttons to move the time forward or backward.
  3. Press SET again.
Note: While you are in clock-setting mode, there's a red clock icon that will show up on the LCD display.
Mar 10, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
Dennis60
Jan 27, 2009 | Audio Players & Recorders
Strange fixed display for GE 7-4612B clock radio
I have this same problem with my clock radio, same model #. I have a feeling that this may mean this clock will be on its way to the dumpster very soon.
Nov 24, 2008 | GE 7-4836 Clock Radio
How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
What I have found with my alarm clock like this one is that you CANNOT be soft on it. When setting the time, hold down the F or R button extra hard. I know that seems odd, but it works!
Oct 14, 2007 | GE (74896) Clock Radio
GE 74901 Clock Radio Logo
559 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
