Question about Refrigerators
My fridge & freezer just started to thaw this afternoon. You can hear the fan running inside.
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 10, 2008
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
FFB6187
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Lights on, sounds like running, everything thawed
Check your compressor, the relay and the computer board. These are all located at the back of the fridge if all check out ok, then check your thermostat
Feb 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Amana refirgerator/freezer combo not working properly
it sounds like a bad:
  • start switch (on the side of the compressor) or
  • compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 01, 2008 | Refrigerators
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
