Question about Maytag Performa PAV2200
Maytag performa washmachine
My wash machine is acting like the load is out of balance, when the drum spins it always spins to the one side of the washer, it will even do it when their is no load in it, all the springs are attached and the machine is level
    Problem Solver:
  • 5 Answers
You could replace the snubber ring and springs,, if you love the machine, and make sure no grease is leaking. It's a lot of labor. These are not the real Maytags of the past.
Posted on Jul 19, 2008
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Jan 06, 2013 | Maytag Performa PAV3200
Maytag Neptune washer always has water in the drum after wash is done? Any ideas? I can hear lots of water left in the washer when I spin the drum manually and of course it has a moldy smell having water...
The liquid is a saline solution which is hermetically sealed in the front balance ring on the spinner. It is there to reduce vibration and acts like a gyroscope when the spinner revolves. Good sound to hear when you spin the basket. The smell can be gotten rid of by using a washing machine cleaner like tide.
Dec 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Mar 31, 2010 | Maytag Performa PAV2200
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Washing Machines Logo
258 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
