Question about Roper Refrigerators
Nothing works except the fridge light - Roper Refrigerators
    President:
  • 1,314 Answers
Look on the control box where you set the temp in the fridge find a hole and with a strange looking plastic screw turn it slowely clockwise if it clicks on and the unit runs then you got a bad defrost timer and need to replace it if not reply to me for futher inst
Posted on Jul 10, 2008
MY HISENSE FRIDGE IS NOT WORKING, THE LIGHT IS NOT ON, AND AM NOT HEARING ANY SOUND FROM IT
Could be a lot of things but if the light is not working (and I'm assuming it is OK) then I would be checking the power supply.
There is nothing else that makes this work except the door switch. Check the power point and if Ok then check for internal fuses. If the light is found OK then check the defrost timer. It may be jammed. Cheers
Feb 10, 2017 | Cell Phones
Frige-Freezer not coming on!
there is really nothing You personally can do to fix it, oyu will have to call a serviceman, i reccommend sears. It is a internal circuit or wire that probably blew and needs to really be fixed by a professional.
Sep 14, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Samsung Fridge/freezer problems
The BBC has an open complaint on these machines and you may be elligible for extended work on this
Feb 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
Lg fridge not cooling... freezer works..
Not knowing the make of fridge it seems like you have a faulty thermostat as in newer fridges most operations are controlled by this.
Mar 28, 2010 | Refrigerators
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridge. compartment warm
Not fridge death. If nothing is running it is a good sign that it is repairable. Unplug it. Where the temperature is located, remove it if you can. There will be two wires connected to it. Connect these two wires together and then plug in the refrigerator. It should run and cool. If this makes it run and cool your problem is the thermostat. Replace it.
If it does not run from above, the compressor may have a burnt overload protector or wire off.
May 26, 2008 | Refrigerators
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
