Question about Dryers
SPEED QUEEN MODEL AGS68AWF-- I'VE CLEANED ALL VENTS. NOT GETTING HEAT.DRYER CYCLES BUT GAS DOES NOT TURN ON. I'VE OPENED BOTTOM ACCESS PANEL AND NOTE THAT THE IGNITER GLOWS AND CYCLES BUT GAS DOES NOT COME. IGNITER CYCLES ON REGULAR BASIS BUT NO GAS? IS THERE A PROBLEM WITH FLAME SENSOR OR GAS SOLENOID? ANY HELP WOULD BE APPRECIATED.
    Novelist:
  • 177 Answers
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Posted on Jul 10, 2008
Why does my gas dryer heat for 30 sec then i hear a click and the gas shuts off?
It's not supposed to run continually, there is a thermostat inside that regulates the temperature to about 130-150F, if it's not in that range you might need to change the cycle thermostat.
Aug 06, 2014 | Speed Queen AGS28AWF Gas Dryer
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
I won't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Speed Queen AGS68AWF Gas Dryers
I have a GAS Speed Queen clothes dryer. I can't locate the model number. It says "Heavy Duty, Multi Cycle, All Fabric Automatic Dryer". I bought it new in September 1972. It has always...
It could be the vent chambers in the bottom of the machine from the front filter to the vent output to the rear exit vent ducting tubes....or the ducting itself. Flexable ducting, if you are using it, are well known to glog due to the multiple ringed wires inside. Flex is not recommended.
Also the gas line should be replaced with a gas flex line....it's the law here in CA.
Jun 26, 2011 | Speed Queen ADG4BR Dryer
Dryer does not heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 24, 2010 | Speed Queen AGS68AWF Gas Dryers
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore gas dryer 110.70882990 runs & heats but shuts off at anytime during any cycle then i restart it & it may run until dry or may shut off a few minutes later ?
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum2_bing.gif attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps. Douglas
Jun 04, 2010 | Dryers
THE HEATING COMES AND GOES DURING TIME DRYING OR
This is a very nice dryer. I have seen this problem before. What you have is an easy fix that sounds complicated. The timer contacts inside are burred from arcing. You must be brave. If all safety's are good, circuit breaker is all good, and lint is removed from dryer and outside vent then you needs ta look inside that timer. Seen it. Go into the timer and clean all the points with a file.
Dec 05, 2009 | Speed Queen AGS68AWF Gas Dryers
Dryer is slow dryng takes two cycles compared to regular dryer
As the model number you provided indicates this is a gas dryer, you need to open up the access panel, above the washer compartment, to clean out the dryer compartment.
It is likely that either the gas burner components have been covered in lint and dust and are getting shut off sooner than they should because of overheating of the thermocouple safety device, etc.
First, make sure that the power is turned off to the washer/dryer unit and turn off the gas supply valve, so you don't have any issues with getting a electric shock or getting a gas leak/build up.
Once you've done that, you can remove the two (2) access screws that will let you get into the lower dryer compartment where the gas burner and control devices are located (this is the panel just above the washer lid, the angled section).
Now vaccum out all the lint and dust buildup you can see and check that everything is free of dust and lint inside this area. Pay special attention to the gas burner and gas inlet orifices, as anything in there can and will cause the dryer to shut off and thus, not operate properly in getting your clothes dry in a normal drying cycle.
Also, check to see that the dryness sensors inside the dryer drum (silver bars up near the top left or right of the dryer drum) are clean and don't have any residue or buildup on them. This can also cause the dryer to register erraticly when using the automatic drying cycles versus the timed drying cycle. Use a good glass cleaner and wipe these sensors with a clean cloth rubbing them briskly to remove any residue or contaminent that might be deposited on the sensors.
Now completely clean out the exhaust vent all the way from the dryer to the outside location of the vent. Having any blockage of the vent can and will cause the thermal overload protective device to function and turn off the gas burner that provides the heat to dry your clothes. So be absolutely certain that the entire vent exhaust is clean and free of any lint buildup from the dryer all the way to the outside vent (yes I mean't to repeat that!) You'll have to remove the outside vent grate/cover to check for any buildup/obstructions there.
Now you can run a load to see if you've gotten the problem solved, if not, it could be a control module, but 80% of the time, it is nothing more than a "housekeeping" issue that causes loads not to completely dry on the first cycle. So please do some cleaning and checking and you should be back getting your clothes dry on the first cycle!
Hope you find this Very Helpful and best regards!
Oct 20, 2009 | Whirlpool WGT3300SQ Dryer
Dryers Logo
174 people viewed this question
Top Dryers Experts
