Question about GPX MW3337G
Hold when i turn it on it askes what music mode i want but i cant move over or enter because whenever i press a button it says hold
    Problem Solver:
  • 8 Answers
Have you checked to see if the "hold" switch is pushed over to "hold"? It is located on the front/side of the mp3.
Posted on Jul 24, 2008
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
Cant get my kdc mp238 out of standby mode. i have entered my 4digit pass code in and it says approved, also tried holding the src button in and pressing the small reset button but after i hit the small...
you should just need to press the source button to change modes.. example, tuner, cd, aux. you don't need to hold it in. pressing it for a few seconds. turns the deck off.
Dec 16, 2010 | Kenwood KDC-MP238 CD Player
Fatal error 428056ec + 4280999c
Hello.
Try resetting the printer:
  1. Power on printer while holding both the "+" & "-" buttons simultaneously; release when "OKIUSER" is displayed.
  2. Press either the "+" or "-" button until "ENGINE DIAG MODE" is displayed; press "Enter" and "DIAGNOSTIC MODE xx.xx.xx" will be displayed.
  3. Press and hold both the "-" & "On-line" buttons simultaneously until "ENG DIAG LEVEL2" is displayed.
  4. Press either the "+" or "-" button until "CONSUMABLE COUNTER SET" is displayed, press "Enter" to go in the menu to set various consumables.
  5. Press either the "+" or "-" buttons to go to the desired consumable and press "Enter": the last digit of the count will start flashing.
  6. Press "Cancel" to decrease the digit amount or press the "On-line" button to increase the digit amount; press the "+" or "-" buttons to move along individual digits in the count.
  7. Once the count is at the level you desire, press and hold the "On-line", "Cancel", and "Back" buttons simultaneously until the "*" reappears next to the count; consumable's count has been reseted to the number specified.
  8. Press the "+" or "-" buttons to move to the next consumable and repeat at step 5.
  9. Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, use the "Back", "+", and "-" buttons to exit through the menus (reverse of steps 2 through 4) until "INITIALIZING" is displayed.
  10. Turn off the printer and turn on.
Hope this helps.
Nov 08, 2010 | OKI C5400 Laser Printer
I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
Hope it helps,
FVazquez
Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Xerox Phaser 8500
Entering Service Diagnostics without Rebooting the Printer:
This method of entering diagnostics is to allow customers to be diverted to service
diagnostics in order to perform some tests.
1. Display the Hidden Service Menu as described in "Hidden Service Menu" on
page 4-2.
2. Scroll down to Enter Diagnostics and press the OK button.
Entering Service Diagnostics by Rebooting the Printer (8400):
1.
Turn the printer power OFF.
2. Press and hold the Back and Help buttons.
3. Turn the printer power ON while continuing to hold the Back and Help buttons
for approximately 30 seconds until the Control Panel indicates Diagnostic
Menu
Entering Service Diagnostics by Rebooting the Printer (8500/8550):
1.
Turn the printer power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the
Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization
. Release the buttons and the printer reboots into service mode
with the Service Diagnostics menu displayed.
May 23, 2008 | Xerox Phaser 8500/DN Printer
Unable to turn off DEMO MODE
1. Turn Radio On
2. Change Source input to Stand-By
( Puts radio in display only Stand By mode.)
3. Press Menu Button
( Gives you standby menu)
4. Toggle display with control knob until DEMO ON appears
5. Hold control knob in until DEM0 OFF appears
6. Press Menu Button
7. Change source back to music.
All done. same as other Fixes - Just step by step!
Sep 09, 2007 | Kenwood KDC-MP435U CD Player
GPX MW3337G Logo
20 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
