Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
1/2 hp craftsman garage door opener just stopped working this evening. When press button on the wall unit the light comes on, but nothing else happens. No noise, no indication that anything is working
  • CESAR  QUANT
    CESAR QUANT May 11, 2010
    release the garage door from the opener and push the wall button again to see if theres some movement?
    Scholar:
  • 143 Answers
You will need to replace the logic board on this. Whether you replace or repair get a surge protector on it 900 joules or higher. You can get replacement parts at searspartsdirect.com. Thanks BB
Posted on Sep 03, 2010
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
Jul 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
IS THE UNIT JAMMED AGAINST THE STOP BOLT ON THE RAIL??
IF IT IS THE CHAIN WILL NEED TO BE RESET RECHECK YOUR INSTRUCTION SHEET.
IF NOT DOWNLOAD THE INSTRUCTION MANUAL FOR YOUR OPERATOR AND GO THROUGH THE DIAGNOSTICS.
HOPE THIS HELPS
Mar 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
I push wall button and hear clicking but won't open
Try unplugging the operator. This may reset any problems you had.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
102 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
