Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Problem with Pre n Router
Hi, I have a Belkin pre n router pluged to a dsl 256 mgb connection, I have one desktop with the Tplink wifi card model TL-WN851N that works up to 300 mbps draft N, and an pcmcia card for my laptop brand Trendnet pre N model TEW-601PC/A that works up to 108 mbps I see in the user manual of the router, the router transmit up to 108 mpbs, BUT THE MAX SPEED OF MY WIFI NETWORK IS 54 MBPS, WHY ????????????
54mbps is what the Belkin routers wireless signal transmits at! This cannot be altered and is working correctly regardless of other wireless card speeds.
Posted on Feb 10, 2009
  • dotNetTech Feb 10, 2009
    Just re-read your problem. 54mbps is usually standard, however you are saying manual says up to 108mpbs. Have you checked the routers settings?
Belkin dual-bank travel router how can i set up in computer
The Pre-Shared Key is your wireless security password, in the form of a word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols, or 64 Hex (0-F) only. Each client that connects to the network must use the same key (Pre-Shared Key).
The key can be found in 3 different places on your router. The first place is on the wireless security card that came included with your router, it comes taped to the side of your router and fits conveniently in a slot on the underside of your router for storage. The security key is also printer on the top right corner of the product label for your router. This is found on the underside of the router. Finally, you can also login to the routers configuration page to retrieve your wireless key. We have outlined these steps below.O keep reading http://www.fixya.com/support/r10611007-setup_belkin
Jan 24, 2013 | Belkin Dual-Band Wireless A+G Desktop...
How do i acess the setting of my linksys router
Hi There
It is very simple to connect Wifi router with your notebook please follow the mention below note and get the solution.
Side A - Wifi Device
Side B- Notebook
Side A -Wife Device
  1. Take a small network cable (patch cable) and put computer or notebook LAN port and other end of cable you put router LAN port.Note:- Don't put cable in Internet port on router,
  2. Go to network properties and click the Internet IP Protocol properties and select the Obtain IP address automatically and click Ok.
  3. After Change the network setting wait few second (While you get the connected network message)
  4. Now go to the run and type "cmd" without quote. then you get the commend prompt. now hear you type the "ipconfig" (without quote)you get the IP Address, sub net mask and Getaway. note the getaway (if the router on default setting then you get 192.168.1.1 Getaway)
  5. Go to the Internet explore put the gateway (http://192.168.1.1) and press enter, the router windows will open and for authentication asking the User name & password (By default user name -admin and password is admin)
  6. After login the router now you have authentication for changing the router configuration. mostly you need to change configuration a your router SSID name or pre-shard key (WAP & WPA) configure the desire SSID name for identify the router while searching and configure the wireless security option and put the pre-shard key.
  7. Now you connect your router with DSL cable and remove the Patch cable,
  8. Turn on your laptop wireless and search your desire wireless in few second you get your wireless in search windows.
  9. Double click for connect when you connect it ask you for pre-shard key for connecting now put the pre-shard key and you connect with router.
  10. Now for checking you just go to command prompt and type "ping 192.168.1.1" and result you get " Reply form 192.168.1.1 .....ect" its mean your laptop and router both are communicate.
More help
For Video
Thanks
Prashant
Dec 19, 2011 | Linksys Wireless-G WRT54G Router
Is there a way to hook into my dsl internet to get wifi
Does your DSL not have a wireless router? If not, you can certainly get one for cheap...walmart has Belkin/Netgear/ASUS wireless routers for about $40...the instructions are pretty straight-forward. It's a cheap and easy. let me know if you need assistance.
http://www.walmart.com/search/search-ng.do?search_constraint=0&ic=48_0&search_query=Router
Jul 19, 2010 | Dell Dimension 4700 PC Desktop
If i have a belkin pre-n router (# F5D8230-4) will i be able to connect with a "G" 2.0 adapter or should i get a "N" adapter. When I told the guys at my local retail, they did not know what a "pre-n"...
Because the routers are pre-N they will support B-N because n isnt standard and is still a little touchy. you will be fine. but the downside, you arent getting the true N speed because your comp is running G, if you could elaborate on your computer a bit more im sure we could find an N internal card to replace the G stock. let us know
Jun 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
My belkin n route is unsecured how do I fix this problem
No, you're not safe.
Disconnect your router from your cable-modem (or DSL-modem).
Reset your router to "factory settings", which _are_ safe.
Mar 22, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Connection between wifi radio and Belkin pre-N router
To reset your router to factory settings ther should be a reset switch on the back you will need to use a paper clip to do. Hold in for about 15 sec to reset.
Sounds like you have customized the router a bit so I would copy your current settings for your network unless you don't have much then I would just start over.
Manuals and info
http://en-us-support.belkin.com/app/product/list/q/routers/session/L3NpZC9GTm0yc1BSag%3D%3D
Mar 13, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin Pre-N Wifi - Speed problem
When using a laptop that has a N-wireless card the computer will to connect to a G-wireless router the laptop will be able to connect but because the router is a G-wireless the speeds will not be as fast. speeds around 10 to 20 Mbps is about normal. I don't know why your computer is saying that you are getting speeds around 108 Mbps. Residential computers don't reach speeds that fast but some business computers running off of an T-3 internet will have speeds up to that high so that they can keep up with large amount of data being transferred over there networks. As for the USB, i have seen an USB adapter that was g-wireless at at Wal-mart for about $20-30.
Jan 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Pre-n wireless router
Check your device to see if it is due for a firmware upgrade. Esp. depending on your ISP, log into your device that you have from your ISP ( whether dsl modem, cable modem, etc.) and then follow whatever procedure it needs to determine your current firmware version.
Jun 16, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin n wireless usb speed problem
For your connection to reach 300 MBps, not only must your Belkin WiFi USB adapter be an N, so must your Access Point/Router also be N capable.  Additionally, your Internet/DSL connection would also be a limiting factor on your Internet Connection speed.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | Belkin Pre-N 802.11g/b Wireless Adapter
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
150 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
