Hi, ALL WAYS UNPLUG THE POWER.
The humming may be the motor itself, or a deficient capacitor.
I suggest taking several pictures of the suspected parts, before anyattempts to fix/replace them.
1- 90% of the time, the most frequent problem is the "starterCapacitor" going bad. It is a metal uncased capacitor, normally attachedto the electric motor. They have a sears number to reorder, and you can replaceit yourself, just unplugging the connecting wires and plug them to the new one.Any electronic place that sells parts may be able to sell you a replacementCapacitor cheaper than Sears.
2- It could be the electric motor itself going bad, if you have low voltage. Ifinstead of 110V you normally have 92Volts, after many times, it burns thewinding coils. Try this: UNPLUG THE POWER AND KEEP THE STARTERSWITCH OFF. Spin the electric motor by hand (you can do it rotating theBELT) about 10 to 40 degrees, this will reposition the coils. MAKING SURETHE SWITCH IS OFF, PLUG THE POWER, and THEN TURN THE SWITCH ON FOR 5SECONDS, if it won't start, turns it off. When this procedure worksmaking the motor to start, but fails again, and every time you use thisprocedure Works, you have a defective coil going bad, "meaning" thatthe electric motor have to be replaced. If this procedure works, you may beable to avoid replacing the motor till the time that it does not work anymore.
3- Also, it may be that just at that particular day, your electric grid has lowvoltage due to high demand, but next day is Okay. Try next day, or when thehigh demand is fix.
