Question about Goodman CLQ36AR49 Air Conditioner
Fuse in A/C unit
I believe I need to replace the fuse in my A/C unit , however I don't know where to find the fuse... a repairman replaced it three years ago but I don't remember where it was located...
any advice would be great!
  • smithm616 Jul 20, 2008
    The unit will not turn on. I have replaced the fuse and battery for the thermostat. The tower is not turning on, nothing is. I have checked the circuits. I can not find the high-limit switch. Is there a fuse I need to replace?
    Champion:
  • 254 Answers
Hi
This fuse is on the control board inside of the furnace. If you take the outside cover off you should be able to see it on the upper left habd side of the circuit board. It probably is either a 3 or 5 amp fuse depending on the size and/or model of your unit.
Hope this helps Ya
please rate me
Posted on Jul 19, 2008
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
Panasonic microwave oven NN-5262SF. Totally dead after electrical storm. Plugged into live outlet. Even the light and fan dead. Believe a fuse in the oven but don't know where it is located. Can you...
Hi pdylhoff,
Try to replace the fuse using the instructions below. Replacing the fuse will determine if it's the cause of the problem.
1. Unplug your microwave. Remove the screws from the back panel. Take off the back panel.
2. Find the fuse. It should be near where the electrical cord comes into the microwave. The fuse is a small white bar with metal caps on either end.
3. Carefully remove the fuse. Avoid touching the transformer or other parts inside the microwave.
4. Take the old fuse into the store to find the exact match. You may also use the owners manual to find out what kind of fuse is used.
5. Replacing the fuse. Please put the cover back on and see if your microwave works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced by an authorized repairman.
Reminder: Please do not touch the transformer on the inside of the microwave. It can discharge enough electricity to cause harm or even death.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Kitchen Ranges
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Can i reset my Konica Minolta C250 transfer unit and fusing unit?? Is there a chip reset that I can buy for the transfer unit and fusing unit? I just purchsed the resets for the image units and they worked...
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Sep 30, 2009 | Konica Minolta bizhub C250 All-In-One...
Power up
Dear Kresten,
it looks like the problem with either your motherboard or SMPS. So, it is advisable to find a repairman in your
area. You can get the repairman in fixya itself.
thanks,
Sep 22, 2008 | Asrock P4I45GV R5 Motherboard
Kenmore Elite Oasis Electric Dryer
Hi! kjsnell
Can you look up the first three digits of the model number and let me if you have any other comments.
Aug 07, 2008 | Kenmore Elite HE4 Electric Dryer
Standby light blinks 6 times
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Nov 03, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
i had the same problem to, i replaced the thermal fuse and everything was back to normal. Be careful if you are a gamer because both times this has happened i was playing my xbox
Nov 03, 2007 | Televison & Video
Blowing heating element
Wow. Doesn't sound normal to me. I have two thoughts going through my head. One is that perhaps the blower fan is bad and not giving it the proper air flow. However the high limit switch should shut off if it gets too hot, which leaves me to believe the thermostat and/ or the high limit switch are bad. Naturally you want to vent the shortest distance possible. Good Luck. I know a good repairman could locate the problem. That's the problem, finding a trustworthy repairman. If you do hold onto him. Good Luck
Oct 07, 2007 | Dryers
Goodman CLQ36AR49 Air Conditioner Logo
162 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
