Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Won't fire S.O.S. Our Laars Lite 2 LG pool heater won't fire up. The pilot is working fine, but when we turn the switch to on and turn up the temperature, nothing happens. We tried to bypass the on off switch and the temperature dial and the pressure switch and nothing happened. We changed the main electrical wires. Any advise would be greatly appreciated!
  • 1 more comment
  • Anonymous Jul 10, 2008
    Same as above .......one year old and won't fiew up.....
  • Anonymous Jul 18, 2008
    I HAVE THE EXACT PROBLEM
  • Anonymous May 24, 2009
    does anybody ever get their questions answered...this site seems like nothing but an advertisng site that pays google for clicks
  • 3 Answers
It may also be the high temp switches under the 2" inlet/outlet header. The 150 degree high-limit switch sits horizontal and corrosion happens often there. But be careful removing as if the header is corroded and the switch is also, water will flow out , so be ready to bypass the heater. You will have to replace the header. Try to jumpe that switch out and I'll bet the heater fires up.
Posted on Aug 07, 2010
It's probably the pilot generator. It can't be bypassed to test becasue it actually generates a few millivolts to open the gas flow to the burner Part #W0036901
Posted on May 27, 2009
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Every year I have a problem getting it to light. The pilot is lit but the heater will not turn on. It is 8 years old and I have been having trouble with it since day one. My pool guy comes out fires it up...
First, check the gas valve and make sure the valve in all the way to "on" not "pilot".After shutting to off for the winter, and not turning the valve all the way on start up could be it. If that is ok, check/replace the pilot generator next to the pilot lite. One question. Does the pilot go out soon after calling for heat? Next, if you have it on "spa" or "pool" on the temperature adjusting module, try the other setting. eg. If it is on "pool", switch the knob to "spa" and adjust the temperature.
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater will not fire up.
Older heaters with "Hot - Cold" turn control can attract spider webs etc. I had exactly your problem and just blew the inside of the control switch with compressed air to clean it out. My heater fired up after that clean up procedure. Hope this solves your problem!
Apr 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
776 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
