Question about Samsung SC-L901 Camcorder
Samsung VP-W80 When trying to watch/capture the tape through the computer or TV the picture is only shown in black and white. There are no settings to change from colour to black and white, so i assume it's due to an internal problem. what's the best way to fix it?
  • sparkleigh89 Jul 10, 2008
    it's definately not the av cable as we've tried with both Composite & S-Video cables and recieve pretty much the same result.
Sounds like the wrong NTSC/PAL output settiing
Posted on Jan 09, 2012
    Problem Solver:
  • 8 Answers
Go into the menu of the camcorderand check if the colour system setting is correct.
Posted on Jul 10, 2008
  • Samsung Master
  • 2,794 Answers
Try another av cable and see if there is a short in it.
  • Tim Babcock
    Tim Babcock Jul 10, 2008
    Have you cleaned the tape heads with an 8mm tape cleaner?
The picture is only black and white and is flashing on my computer screen. Sound is good.
Usually, this indicates that video source is PAL but the capture is set to NTSC, or that the video source is NTSC but the source is PAL.
Make sure that the video capture device is set to match the signal of the input.
PAL is used in Europe, NTSC in North America.
How you set it depends on the Video Capture software you use, but look for PAL/NTSC setting and switch it.
Apr 18, 2011 | Diamond Multimedia ( VC500) Video Capture
When I connect my camera up to the one touch video capture card my diamond media the video camera picture flickers. Can you help me? thanks.
I had the same symptoms - black & white flickering image.
The problem was that my video source was PAL (European) but the software was set to NTSC (USA) video signal format. When I changed this, it was normal colour video without flicker.
I happened to be using AVS video recorder but similar settings probably exist in most capture programs.
Mar 28, 2011 | Diamond Multimedia ( VC500) Video Capture
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Mar 06, 2010 | Ulead Videostudio 8 for PC
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Black And White
Yes, there is a way to change this to color. If you are in the US, make sure you have it set to NTSC or PAL if you are located in Europe.
Mar 16, 2009 | Sabrent SBT-TVFM (188218000729) Video...
No Picture
i do know that this unit which i have also if you plug the tv up and turn it on several times it will reset the tape drive and take out all slack on the tape and it will then eject the tape then clean the tape path after you get tape out tv should return to normal but tape unit must be cleaned are the sensor mabe going bad like the end sensor and so forth etc..
Dec 17, 2008 | GE 13GP344 13" TV
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
change the software to sage tv or beyond tv or if you are using windows vista try the media center
Oct 25, 2007 | Hauppauge WinTV PVR2 (99016) Video Capture
Dimage E40 TV picture stability
In black and white? If there is a red and yellow, white and yellow, or red white and yellow on the tv end make sure the colors are matched correctly. Try on channel 3. Try on another tv. Is the camera from a foreign country? (Might be PAL, not NTSC.) If so, there should region menu in the camera to change this. For video, you have to shoot it in the mode of the TV you want to watch it on. North American TV's are NTSC, so shoot with the camera in that mode. If you shoot in PAL mode, a north american TV will show a black and white rolling picture. Just about everywhere else in the world is some version of PAL.
Sep 13, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Samsung SC-L901 Camcorder Logo
178 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
