Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Password stopped working after windows updates
My windows password stopped working after windows updates downloaded. I did not change it and I am the only person who knows the password. The computer will not start in safe mode - when I try to start it in safe mode, it just lists a bunch of files. PLEASE HELP!!!!! The computer worked fine last night.
  • 9 more comments
  • goincrzy Jul 10, 2008
    restarting - hold on
    The whole page is a list
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS\system32\drivers\pci ide.sys
    These are some - safe mode did start, but it still asked me for my password and it did not work.
    I can't get past the password.
    how can I run a virus check - I can't get into the computer?
    The files say partition(2) is that normal?
    how did you check for the virus if it wouldn't reboot? Were you able to get it fixed?
    thank you!!!!
    that means I will lose everything on my computer, right???
    thank you for your help - I really appreciate it. I think I will tackle that when I am more awake and not ready to throw the computer across the room. Thanks again.
    I hit F12 to go to the boot menu and it let me run diagnostics tests - says it takes an hour or so - worth a shot - don't know if that will check for a virus or not though??
  • goincrzy Jul 11, 2008
    I found this solution on the site and IT WORKED!!!!! I copied it from another thread. I can get back into my computer and I did not lose any information. I had to have another computer to be able to fix it because I had to re-download Internet Explorer 7 - mine kept opening windows and closing them. Now everything is working great!!! Scanned the computer and it did not find any viruses. Maybe the trash files got overwritten?? Don't know, just know it's working and THANK YOU FOR THIS WEBSITE!!!!
    Best Solution
    posted on Feb 23, 2008
    Rank: Wiz
    Rating: 84%, 78 votes
    1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
    2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
    3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
    4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
    5. The Licensing Agreement comes next - Press F8 to accept it.
    6. The next screen is the Setup screen which gives you the option to do a Repair.
    It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
    Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
    7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
    8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
    9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
    10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
    11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
    12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
    13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
  • 43 Answers
Sounds like you got a virus.what do the files say?i can tell you more if i knew alittle more.
Posted on Jul 10, 2008
  • 5 more comments
  • patricia massingill Jul 10, 2008
    is this all it will do after start up?
    still sounds like some how you downloaded a virus.thats similar to what happened to computer had a virus and i couldnt get it to reboot in normal mode you need to some how run a virus check first.
    let me get back to you im going to ask some one who deals with this kind of thing and i'll post it back on here for you.
    yes i finally had to use my flash key when it was in safe mode to download the virus checker.but yours is alittle more complicated you can even get into your computer and thats got me puzzled updates usually don't do that.
    ok you may have to reinstall the operating you have it?what ever happened when you were installing your updates as we know froze your computer to keep it from letting you on try installin your operating system.i have ran into many problems but this one is new one on alot of us.
    yes thats why when you reinstall it you start over with a new password if you prefer to do cant get into the computer this way so try something else reinstalling the operating system should help it and if it does not then i would be thinking it is a virus because i tried that on my computer and it wouldnt let me reinstall my operating system.this way you'll know for sure.
    well it's worth trying anything to keep from havin to lose your info.good luck let me know what turns up.
I can't log on to my PC because I don't know my Windows password. How do I change password?
Official page said:
What to do if you forget your Windows password Windows Help
If you are an user and you have also an administrator account available (and enabled) you could use it to change personal account,(maybe is necessary use F8 to force auto-logon and enter in "safe mode")
otherwise, some utility that can help you:
Aug 17, 2015 | Dell Computers & Internet
A Ways to Fast and Free Security Enhancements
Before you spend a dime on security, there are many precautions you can take that will protect you against the most common threats.
* Check Windows update and office update regularly or with your windows & office CD ready. Windows 2000, XP and Vista users can configure automatic updates. Click on the Automatic Updates tab in the System control panel and choose the appropriate options.
* Install a personal firewall. Free versions.
* Install a free spyware blocker. Spybot is also paranoid and ruthless in hunting out tracking cookies.
* Block pop-up spam messages in Windows or others system by disabling the Windows Messenger service (this is unrelated to the instant messaging program). Open Control Panel ] Administrative Tools ] Services and you'll see messenger. Right-click and go to Properties. Set start-up Type to Disabled and press the Stop button. Bye-bye, spam pop-ups! Any good firewall will also stop them.
* Use strong passwords and change them periodically. Passwords should have at least seven characters; the letters and numbers and have at least one symbol. A decent example would be f8izkro@l. This will make it much harder for anyone to gain access to your accounts.
* Of your using Outlook or Outlook Express, use the current version or one with the Outlook Security Update numerous vulnerabilities.
* Buy antivirus software and keep it up to date. If you're not willing to pay, try Free Edition. And doublecheck your AV with the free, online-only scanners available.
* If you have a wireless network, turn on the security features: Use MAC filtering, turn off SSID broadcast, and even use WEP with the biggest key you can get. For more, check out our wireless section or see the expanded coverage in Your Unwired World.
* Join a respectable e-mail security list, such as the one found Security Supersite so that you learn about emerging threats quickly and can take proper precautions.
* Be skeptical of things on the Internet. Don't assume that e-mail a particular person is actually from that person. Don't assume that an attachment is what is says it is. Don't give out your password to anyone, even if that person claims to be from "support".
on Dec 21, 2009 | Computers & Internet
How can I open my Samsung when it is asking for a specific person's password that I do not know
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
Jan 08, 2013 | Samsung V20 XVC 2400 Notebook
How can change my password on yahoo messenger?
Here's how to change your Yahoo! password from within Yahoo! Messenger:
1. Click the Messenger menu and select My Account Info. The Sign in to Yahoo! window opens.
2. Enter your current password in the Password field and click Sign In. The Account Info page opens.
3. Click Change your password. The "Change your Yahoo! Password" window opens.
4. Enter your current password in the Enter your Current Password field.
5. Enter your new password in the Choose a New Password field.
6. In the Confirm your New Password field, confirm your new password by entering it again.
7. Click Save to put your new password into effect. You'll see a message that says you've successfully chosen a new password.
8. Click Continue. You'll be asked to review account sign-in settings. Make any updates to this information that you would like.
9. Click Continue again. You'll be returned to the Account Info page.
10. When you're done, be sure to click Finished.
Article Source from:
Change Your Yahoo Password Easily by Firefox Password Recovery (You can google search for : Smartkey Firefox Password Recovery )
change yahoo password
Apr 09, 2011 | Yahoo Messenger
I try to log on to my computer but it keeps telling me my user name or password is incorrect. I have not changed anything. (windows7)
Try typing your password in CAREFULLY and and make sure caps is off (if applicable). if that doesn't work, you'll have to burn Trinity rescue kit onto a cd, and boot from cd so you can reset the password.
Feb 25, 2011 | Gateway DX4820-01 PC Desktop
Want to remove windows administrator pass word
Usually, there are very 2 easy ways to reset Windows password after it is forgotten.
One is: use another administrative user on the Windows computer to change or remove the already forgotten Windows password.
And the other way to reset password Windows: use a previously created password reset disk. Some people may still not know how to create such a disk.
Below are the detailed tutorials:
Feb 09, 2011 | Computers & Internet
Need to reset the administrative password for my windows xp desktop
Hi there Allenia,
To reset the Administrator user, you need to right click your My Computer and choose "Manage". The Computer Management window will open. Expand the Local Users and Groups from the left panel and click Users. Right click the Administrator user shown on the right and click Set Password. Click OK. That's it!
Please let me know if this helps. Good luck!
Dec 22, 2009 | Microsoft Windows XP Home Edition
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
How do I get ride of the message: "Vaio Sat Survey.exe has stopped working" on my new VGN-NW 120J
Hi There !!
Thank you for writing to
The Sony Vaio softwares are not updated correctly, That's the reason it might be crashing, on the other hand you always need to consider the Windows Update as well. My suggestion would be:
  1. Click Start
    vistastartbutton.jpg in the Start Search box.
  2. Type msconfig, and then press ENTER.
    securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  3. Click the Startup tab, and then unchecked the Vaio Sat Survey.exe, if you find it.These are software that Computer Manfacturer installs on your system initially & they rarely good for the users.
Now after that, Go to windows update & perform the Windows Update.
Need help with windows update, check the link below.
After installing all the latest updates, Restart the machine.
Hope this will help.
Sep 02, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
