Question about Dryers
Dryer won't start.
My Maytag Atlantis dryer won't start at all, regardless of the position of the cycle dial. When the start button is pressed, it buzzes as if the cycle is at the end.
DISASSEMBLE MAYTAG DRYER
Posted on Sep 29, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag Dryer LDE5914 Buzzes when you press the start button but won't turn. Diagnosis? Does it need a motor?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Won,t turn off timer does not move , but was changed but still the same its a maytag atlantis .could it be the sensor assembly.....timer does not move in any position.but when moved physically in off...
Here,s what I found!!! Have 3 cycle's
; time dry, wrinkle free, and regular. I was told the dryer wasn't shutting off and the timer was not advancing, which was made evident by the fact that when we came home it was still running, which I have seen. Please keep in mind I have two adult children who use the dryer. Took off the back of the control panel ( make sure power is off at the breaker or unit is unplugged ). I vacuumed all the lint out of the back, it was considerable! Then made sure all spade terminals were tight and free of corrosion. I've been a nuts and bolts electrician for thirty years and extremely strong troubleshooter so I thought, "perchance I'm getting bad info". I ran all 3 cycles at every temp. setting and saw the timer advance ( it takes about 15 min. to see a real change ). It could be that the "lint" was shorting out wires ( that would be the same as closing contacts at the wrong time ) and causing the timing function not to work. Anyhow, make sure you look at everything before you start buying parts that may not be necessary. Hope this helps.
Guest
Feb 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Will not start
Replace the timer control asap. it has failed.
Jun 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
MAytag performa dryer won't turn on
does it make a humming noise when you press the start button
Jun 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
