Question about Vacuums
How do you install a vacuum belt for Hoover soft and lite supreme????
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=764033
Generic problem for all Vacuums
Posted by winklefishxo on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Remove the bottom plate by removing the screws, clips or levers and then if you cannot get @ the belt from the bottom then the top cover should come of and then you can get @ the belt. Cut the old belt off and then lift up the side of the brushroll with the belt pulley, then slide the new belt onto the belt pulley and re-install the brushroll, then use a belt puller or a screwdriver with a left or right hand hook and then stretch the belt onto the motor pulley and then track the belt so that it is running in a straight line. Now, replace the bottom plate.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Replace belt - how do I get off the interior housing
Rather than try to explain this procedure by typing it, I'll give you a link to an online guide with pictures that show the procedure. You'll see two links on the page regarding belts , look at both and use the one that is closest to your model. Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Hoover Soft and Light Supreme U4266-930...
The brushes are not going around and, of course, not picking up hair, fuzz, etc.
check the belt that turns the brush, it sometimes gets worn and looses friction, causing loss of spin.
Jul 06, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
Can't get to motor to connect belt after removing brush cover
I followed the instructions that were supplied @ the FixYa site, to remove the hood. Removing the hood was the problem. Just follow the online users manual pages 22 thru 26. you must spread the hood by the rear wheels to remove. Thank You Very Much. Delano
Jun 29, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
How do I change the belt in a Hoover U4262-930
You got the second hardest part done; the hardest part is what you're asking about.
To get the new belt onto the drive shaft I used a long screwdriver for leverage and wrapped the end close to the shaft and with some elbow grease, got it to "slip" on to the shaft. It took a couple of tries, but once I overcame the fear of the belt breaking (because it has to stretch big time), I managed to get it one. Of course, the other end of the belt has to be wrapped around the roller first.
I found a link for a tech manual for this model, but it didn't help much....
good luck.
Mar 22, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
HOOVER VACUUMS
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Aug 11, 2007 | Hoover Soft Light Supreme U4262-930 Bagged...
Vacuums Logo
79 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
