Leaking washer I have a Frigidaire stackable top load washer and dryer. The washer is leaking a lot of water from underneath. What could be the problem? Thanks Jodi
    Genius:
  • 1,028 Answers
Remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Posted on Jul 10, 2008
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
Washer and dryer stackable unit. water is leaking from somewhere onto the floor causing floor swelling. what could be the problem?
Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
Apr 22, 2011 | GE WSM2420T Top Load Stacked Washer /...
Stackable washer (bottom), top load leaking water??
Easy fix most likely the water pump is leaking or the hose from tub to pomp. Remove the front cover
A couple of screws at the base come out and you can remove the front.
Run is a while with the cover off to see where the leak originates but
keep the pets and children away from the machine while the cover is off.
Tip it back to remove the belts.
Feb 10, 2011 | Maytag LSE7806A Top Load Stacked...
I have a stackable washer and dryer and water leaks out the bottom as fast as it comes in and when i saw it leaking i tryed to spin it to **** the water down the drain instead of the floor and it started...
Chances are that if water is coming out of the bottom very rapidly a clamp or hose has come loose off of the tub or pump. Also, since that is a stackable unit it should be very easy to check. Tilt the machine back and there should be 2 screws or fasteners holding the front panel in place. If it is not a hose the only other thing would be a crack in your outer tub. (It would have to be one heck of a crack too).
Aug 16, 2017 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fridgaire washer is leaking water about 1/2 gallon of water
If you take off the front panel in the VERY back you will see a hose, that hose has seemed to have come disconnected, there is a valve back there that is just slips onto. This will stop your water leak
Feb 08, 2009 | Frigidaire FWS833A Top Load Washer
Washing Machine is draining on my floor
look down to the bottom of front panel..see a srecw on each side remove than slide panel straight down...onthejob
Jan 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
258 people viewed this question
Top Washing Machines Experts
