Question about Jenn-Air Refrigerators
Jenn-Air JCE2389GE Side by side freezer freezes up, Frig gets warm
    Sergeant:
    Champion:
  • 330 Answers
Check the blower see if it is working.
Posted on Jul 10, 2008
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer not defrosting
Most likely there is a leak in your freezer seal allowing moisture to build up and form the ice blockage.
Jun 17, 2009 | Jenn-Air JCD2389G Side by Side...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
WHIRLPOOL side by side freezer works fine but frig warm
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Jan 20, 2009 | Jenn-Air JCD2389G Side by Side...
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
JCD2389GES SIDE BY SIDE
hi thanks for the question if you say that the fan is not working replace the fan thanks the appliance doc
Aug 23, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Jenn-Air JCD2389GEB side by side
the clicking noise is the motor overload. have a service tech check for a freon leak.
Sep 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
57 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
