Question about HP Office Equipment & Supplies
I have printer HP PSC 500 S/N SGH02E112T WORKED FOR 5 YRS - NOW WILL NOT PRINT EXCEL SPREAD SHEETS OR WORD DOCUMENTS - STILL PRINTS EMAIL AND INTERNET DOCUMENTS HAVE HAD OTHERS CHECK SETTINGS AND CANNOT FIND PROBLEM - PLEASE HELP EMAIL pbshelley523@hotmail.com - PH 214-295-8194 phil shelley
    President:
  • HP Master
  • 1,314 Answers
When you print from word or excel, click on file, then print. Is the printer listed there? Click on that printer then select print.
Posted on Jul 10, 2008
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
My hp psc 1315 is not printing all the information from Excel spreadsheet. It appears to be dropping off information. Is this a printer problem or an excel problem
Have you looked at the pinter preview to see if the information is on there before you print. If the info has dropped off befor you print, this could be due to the wrong format size of the paper. Sometimes the printer prints out two sheets which you put side by side for full view.
Jul 12, 2010 | HP PSC 1315 All-In-One InkJet Printer
Can't print from the internet but will print emails and other documents saved on my computer
I understand your concern that you are unable to print from Internet explorer. To resolve the issue you need download and install the HP smart web printing software. Click Here for the HP smart web printing software and select your Operating system and download the software.
May 22, 2009 | HP PSC 2355 All-In-One InkJet Printer
I need to print on 5 x7
Go into the print settings and change the size of the document there. The printer may be set to 5x7 but the document you are printing isn't.
Jan 10, 2018 | HP PSC 1315xi All-in-One Printer
I have printer HP PSC 500 S/N SGH02E112T WORKED FOR 5 YRS - NOW WILL NOT PRINT EXCEL SPREAD SHEETS OR WORD DOCUMENTS - STILL PRINTS EMAIL AND INTERNET DOCUMENTS HAVE HAD OTHERS CHECK SETTINGS...
Friend,
There's apparently a problem bwtween your Office suite and the spooler. Usually uninstalling/reinstalling the Office suite will fix the problem. (please do a backup of all your Office documents before proceeding!)
When reinstalling, please make sure that any antivirus program is shut down or deactivated during install, in some cases for example Norton Antivirus will block files that need to be updated, causing problems. You SHOULD use some form of virus protection when using your computer, don't get me wrong! :)
//Al
Mar 08, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer malfunction in a psc
You are out of ink, you must replace both cartridges to get it running.
Jan 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
71 people viewed this question
Ben Johnson
