Question about Hitachi DZ-GX3100A DVD Camcorder
Unavle to remove disc
The unit sounds as though it's "trying" to release a latch; slight whiring noise, a half dozen or so quiet "clicks", then nothing. The disk is full and finalized, I presume. But it won't come out....:( help? is there a manually release for the cover somewhere? I tried gently prying when it's trying to open, but no luck. I don't want to damage any further. Out of warranty, sadly.
  • Trace-P38 Jul 10, 2008
    I appreciate your response, however, I have the manual, and consulted it thoroughly before posting here. The disk will play in the camera, so it is installed correctly. I've tried to eject disk with a fully charged battery and on AC power. Same thing either way. The "ACCESS PC" light blinks 4 series of 6. (Yes, there is a slight gap difference between the sixth and first of next series.) This takes 18 seconds. During this time, there is "click...click....click-chunk" to be heard 4 times in succession within the camera. the last series doesn't end with the "chunk." I believe the camera is "trying" to unlatch the cover 4 times , but can't. It then gives up. Any further suggestions? Manual release anywhere, like a cd player has?
  • Trace-P38 Jul 11, 2008
    Okay, thanks for the help. I took matters (and a small screwdriver) into my own hands and opened the unit up from the top. Under the non-functional hot shoe are more access screws,btw. It seems as if the problem was in the small nylon gearing located under the zoom slider. There is also a mechanical latch for the disc access cover, on a spring, in this area. I "bumped" the gears with the screwdriver just after pressing the disc eject button, and the latch mechanism worked. 20 successive attempts yielded 20 successful openings. While I was in there, I drilled a small hole through the top plastic cover piece enabling me to manually manipulate (with a paperclip) the mechanism to unlatch, if the problem should reappear.
  • 2,794 Answers
Here is a link to the manual
See pages 38 & 39
Posted on Jul 10, 2008
  • Tim Babcock
    Tim Babcock Jul 11, 2008
    It doesn't look like there is one. I'm surprised they didn't put one on there.
    If you take into Best Buy they could know the answer to that question.
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Yellow light and red beeps ps3
to solve this problem... download the repair guide of ps3.. click here to get it and solve any problem of ps3..
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Power is on, but it won't work at all.
Try pushing the bobbin winder to the left. if that doesn't solve it and it still makes a whirring noise the belt is probably off the handwheel and will need to be seen by a technician.
sewman7
Oct 27, 2008 | Singer 7436 - INGENUITY
Samsung v20 disassembly
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Sep 03, 2007 | Samsung V20 XVC 2400 Notebook
Wii will not CDs anymore
continuous clicking could be a few gear-related issues: -if the pinion gear is slipping against the rack for the disc-load mechanism, you can try to re-align the rack (hopefully it was just forced out of place and can be clicked back). i would suspect this if the noise is relatively quiet and very fast. -if something is jamming the load mechanism, like the rack is stuck, the pinion gear may be clicking over the teeth of the rack. i would suspect this if the noise is loud and slower. Either way, you'd probably need to open the console. )=.
Jul 11, 2007 | Nintendo Wii Console
Hitachi DZ-GX3100A DVD Camcorder Logo
93 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
