Question about Kole audio Q1-3000D Car Audio Amplifier
Protection light my protection light somes on and stays on. everything is hooked up and i dont know what to do
    Problem Solver:
  • 10 Answers
Hello. First, disconnect all of the speakers the amp is driving and the rca inputs while the amp is off. Now power on the remote. If the prot. light still stays on you will need to varify that the voltage across the ground and b+ terminals is a minimum of 12 volts. If this is true than your amp may be damaged due to shorted parts. Otherwise, try to repower the amp while a speaker is connected and if it is O.K. than there may be a problem with the RCA ground in the head unit or the amplifier. We service these amps at Sound Repair 321-690-0808.
Posted on Jan 28, 2009
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
Power protection light stays on blue,i hooked up a fosgate 10'' woofer to one side and i get nothing? i dont get enough out of this thing to push 6'' mids what can ido?
you have your speakers hooked up inproperly the amp is going into protection because you are presenting it an ohm load lower than it is able to operate at... go to www.the12volt.com and go to the subwoofer wiring diagram section and you can go over your options...
Dec 11, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Protection light
take the amp out and hookit up to the car battery and let it charge then unplug it do this a couple of times then rehook it to the cars audio system it sounds like your amp may be locked..
also check your speaker wires from amp to speaker box then from the back of the box to the speaker inside the box you may have a short..
thats where i would start.. hope this helps
Dec 19, 2008 | Car Audio & Video
I really need ur hlp badley
If the protection light is lit, the amplifier probably has shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect mode - Troubleshooting
Nov 05, 2008 | Car Audio & Video
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
Protection light
have you wired it up properly + to + and - to - and the power + and -
Aug 13, 2007 | Power Acoustik GOTHIC OV4-600 Car Audio...
Kole audio Q1-3000D Car Audio Amplifier Logo
142 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
