Question about Mitsubishi VS-60705 60" Rear Projection Television
VS-60705 60 have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
  • 3,037 Answers
This is not a problem with the convergence circuitry which would cause a 3D picture. The problem you have is in the deflection circuitry. A repair on this would be challenging and we would most likely need a scope. A repairman may be a good idea and the repair cost will be in the $400s
good luck and let me know if you have any further questions
Posted on Jul 10, 2008
    Genius:
  • 1,226 Answers
Please try to reset by unplugging to the wall outlet for a while and then switch back on. some case can be resolve using that procedures. if not then you have to examine the all the connection inside or maybe you show me the picture of the problems to be analyze perfectly.
may be you need to re soldered some connection if the TV has no warranty at all. but if there is then you avail the warranty recommended.
melnavz
    Master:
  • 848 Answers
The picture is flipped left-to-right or is upside-down or both. This cannot happen as a result of a failure. For a CRT-based TV or monitor, it almost certainly means that the wires to the horizontal or vertical deflection yoke have been swapped to enable the picture to appear correct when viewed via a mirror (horizontal only) or if the unit were mounted base-up to a ceiling (both). The remedy is simply to swap the two wires to the relevant deflection yoke(s). There may even be obvious splices to guide you. There is usually a connector with 4 relatively fat wires that go to the deflection yoke on the CRT neck (NOT the PCB attached to the tube base). If you don't have a schematic, trace these on the main PCB back to their origin. The horizontal will originate somewhere in the vicinity of the flyback transformer. It may be possible to disengage the wires from the connector shell and swap them there. If not, cut, splice, and solder. Adjustment of the appropriate centering controls may be needed. For flat panel displays, it is even more unlikely this would happen as a result of a hardware failure. Most likely, there is a mode setting in the one of the setup menus for the TV or monitor itself. It could also be in the receiver for the TV, or the driver or application software of the PC. If the source is a video projector, the menu setting is likely there, to select between front and rear projection (horizontal) or table or ceiling mount (both). So, don't bother to open up the flat panel TV or monitor. The problem is not there! :)
Mitsubishi has a problem
Ur Horizontal/Vertical ic stablizer is dead or it supporting componnents.90% is ur IC.
Aug 25, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
