Question about Electrical Supplies
Poulan chain saw carb tune
I rebuilt the walbro carb on my chain saw. It starts and runs fine but tends to die at high rpm under load. You have to feather it to keep it running. Once it dies it will not start until cool. I tried adjusting the high mix screw. Does not seem to make much difference. Start at 1 1/8 turn all the way to 3 1/2 turns. My weed eater does the exact same thing.
  • donaldly Jul 10, 2008
    Walboro carb high RPM problems
  • Anonymous Sep 25, 2008
    I have a Poulan Predator and it does the same thing. I wanted to try to adjust the fuel mixture but cannot find a tool to adjust. The adjusting screws are rounded at the end and will not take a screwdriver or sockets. I have changed fuel filter, cleaned air filter, cleaned muffler-spark arrestor, checked spark plug, and checked fuel line for leaks. I have not solved the problem. This is why I think it is the fuel mixture. My saw starts up okay, but I cannot let off of the throttle or it will die. Then I cannot start it until it cools off. Does anybody have any suggestions?
Starts with the choke then shuts down when you shut off the choke. what is the settings for the carb
Posted on Oct 14, 2009
Under heavy load it will suck a lot more fuel. The fuel line could be pinched but not completely cut off the fuel flow. Under load it may not be able to deliver enough fuel. Check the point where the fuel line passes through the fuel tank. That could be a possible pinch point or it could have a restriction at that point or somewhere else in the fuel line.
Posted on May 01, 2013
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Oct 09, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
The small saw serial #1J295L669 starts O.K. and runs for about a minute, but then dies on me. there is a high and low adjustment screws;however the cover over the carb. seems to have an effect before and...
Most of carburetor has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed.
Sep 06, 2011 | Poulan Garden
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 42 cc 18" poulan chain saw I cant get it to idle its either all or nothing. I cant start if the chain break is on and when it starts the chain runs. It dies under stress and then is a...
If the chain runs at idle, or tries to turn when cranking the saw, then there is an issue with either the clutch drum bearing or the clutch spring has become weak, to get to both of these components you need special tools, the tool to remove the clutch is part no. 530031112, and the tool to adjust the carb screws is part no. 530035560, the L screw will adjust from idle to half throttle including acceleration, the H screw will adjust the full engine speed
Apr 03, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I rebuilt this carb and it is geeting way to much fuel do you have a parts brake down and assembly instructions? The carb # is WT324
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands as well. Hope this helps!
Oct 16, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Screw mixture settings
1 1/2 turns open. Start unit then fine tune from there.
Apr 11, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Mar 25, 2009 | Poulan ES350 16" Chain Saw
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Electrical Supplies Logo
550 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
