Question about Mitsubishi VS-60705 60" Rear Projection Television
Tv problemsMitsubishi VS-60705 60 in....
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
  • 3 Answers
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Posted on Oct 31, 2008
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
VS-60705 60
The picture is flipped left-to-right or is upside-down or both. This cannot happen as a result of a failure. For a CRT-based TV or monitor, it almost certainly means that the wires to the horizontal or vertical deflection yoke have been swapped to enable the picture to appear correct when viewed via a mirror (horizontal only) or if the unit were mounted base-up to a ceiling (both). The remedy is simply to swap the two wires to the relevant deflection yoke(s). There may even be obvious splices to guide you. There is usually a connector with 4 relatively fat wires that go to the deflection yoke on the CRT neck (NOT the PCB attached to the tube base). If you don't have a schematic, trace these on the main PCB back to their origin. The horizontal will originate somewhere in the vicinity of the flyback transformer. It may be possible to disengage the wires from the connector shell and swap them there. If not, cut, splice, and solder. Adjustment of the appropriate centering controls may be needed. For flat panel displays, it is even more unlikely this would happen as a result of a hardware failure. Most likely, there is a mode setting in the one of the setup menus for the TV or monitor itself. It could also be in the receiver for the TV, or the driver or application software of the PC. If the source is a video projector, the menu setting is likely there, to select between front and rear projection (horizontal) or table or ceiling mount (both). So, don't bother to open up the flat panel TV or monitor. The problem is not there! :)
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Tv repair
try resoldering the vertical output IC and the horizontal output transistor. It sounds solder related
Mar 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-60705
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
518 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
