Question about Amana ATB2132ARQ 33" Top Freezer Refrigerator w/ 21 Cu. Ft. Capacity, Central Cool System & Glass Sh...
Atb2132arq amana
The compressor runs,the freezer is cold kind of but the refrigerator is not.The fan in freezer is not working.
  • 481 Answers
It could be just the fan motor bad or ice buildup blocking the fan from turning. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 10, 2008
  • Mike Durland
    Mike Durland Jul 11, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
ATB2132ARQ amana refrigerator the refrigerator part is freezing on low setting, freezer part is ok
Carl has the compressor been running continuous? Also between the freezer and fresh food compartment you will have a damper control hiding behind the controls. Some have a lever arm that helps adjust the damper to reduce or increase airflow from freezer and it is possible that the damper has become stuck wide open or the lever arm that when you slide the arm to adjust damper has come loose from the damper. Click Here for large photo=> Amana ATB2132ARQ Controls If your thermostat will not turn off then we may have a problem with=> 63001358 Thermostat Control as it could be bad and out of calibration. This is an interesting problem and would like to know what you find and resolve the problem. If this solution is helpful please rate, if not ask until I can help you fix this. Freezing fresh food is not good so I will be here to assist you, Thanks, Sea Breeze
Nov 14, 2011 | Amana ATB2132ARQ 33" Top Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Amana SRD520T - appliance tripped the circuit breaker. After power had been restored the compressor ran but no cooling in freezer or fridge
With the compressor running, open the freezer and listen if the fan is running. If it is not, replace it. Most likely, this is your problem.
If it is running, turn off the refrigerator. Remove the rear panel from the freezer. Inspect the coils. If they are covered in ice, let them thaw completely. This ice will prevent the freezer and consequently, the refrigerator from getting cold.
If the fan works and the freezer coils are not cold, then I am afraid it is time for another refrigerator.
Feb 05, 2010 | Amana Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
My refrigerator
is the compressor running?. check the compressor at the back side of the refrigerator.
Feb 21, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
127 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
