Question about GE Profile JT952 Electric Double Oven
F2 fault when baking oven will shut off displaying f2. Attempts to restart are successful about half of the time, but then it will shut off after about 5 min. GE wants 99 bucks just to show up and won't troubleshoot. This is a problem with the conventional oven not the convection. Thanks much...Mike
  • mdshea101 Jul 10, 2008
    Thanks!!! now i have to see if i can get a sensor and fix it myself!!!
  • 3,037 Answers
Most likely the temp sensor went bad, this is located within the back panel of the oven and will need to be replaced. GE is known to have problems with many of their ovens and I would recommend replacing the temp sensor with one that will handle more heat. Let me know of any other questions that you may have.
good luck
Posted on Jul 10, 2008
  • GE Master
  • 13,433 Answers
F2 would be a temperature sensor is faulty it thinks that the oven is too hot.
    Scholar:
  • 148 Answers
  • 1 more comment
  • derek martin Jul 10, 2008
    oven temperature sensor you can order it from this link
    youl see it in the back of the oven
    you can do it yourself if you can get to the back panel,youll have to pull out your oven out of the wall unless you have an access panel,unplug stove,unscrew back panel youll see the wire going to the probe unplug wire,not from the probe side as the wire and probe are one,bout the connector,go inside the oven unscrew sensor probe,reverse procedure to put back in
E6 F2 Fault Code on left side Display panel of Whirlpool Accubake Upper oven. There is No Cancel Button on the Display Key pad. Double oven unit has just been cutting off in middle of Bake Cycle.
this is usually a problem with the keypad, most techs would say to replace the keypad, if that doesnt solve it, the main board will need to be replaced. make sure your connectors are tight if you decide to kill power and replace the keypad
Dec 20, 2016 | Whirlpool Ovens
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
Turn oven on to bake when it reaches temp oven cuts off and f2 sh
This indicates the oven has reached an over temperature. You will first need to check the temperature probe for the proper reading. Refer to the tech sheet located somewhere on your stove. It should be around 1100 ohms. If this checks out good the ERC electronic range control will need to be replaced. Here is a couple links that should help
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenerc.html
Jul 27, 2010 | GE Profile JTP18 Electric Single Oven
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
GE Profile JT952 Electric Double Oven Logo
150 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
