Question about Harman Kardon Audio Players & Recorders
My harman kardon AVR 335 7.1 receiver is not outputting any video or audio signals. It powers on no problem. I currently run my direct TV box and Harman Kardon DVD player through the receiver to my plasma TV but it displays no signal on the TV. It has been working fine and just stopped working while I was watching TV.
4 Suggested Answers
WolfenHawke
  • 13 Answers
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Posted on Nov 26, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Posted on Apr 03, 2010
Problem with Harman Kardon AVR-70II Turning on
you must open the receiver in order to Test the relais for dirty contacts or faulty. Try to clean the contacts with contacts cleaner, or see any loose wires around and resolder the wires from coil
God bless you
Oct 11, 2013 | Harman Kardon AVR 70
Monitor output signal
Email or call the manufacturer
http://www.harmankardon.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=AVR%20254
Aug 27, 2012 | Harmon Kardon Harman Kardon Avr 254 7.1...
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Apr 06, 2010 | Harman Kardon AVR 135 Receiver
Cripes, been working great for several years, (My Harman Kardon AVR 335) but my coffee maker shorted out and trip the circuit breaker in my house that must also be in line with living room. Of course I...
Sounds like it's in protection mode, receivers do this so avoid circuit damage. It's usually only when speaker connections are shorted, but here it appears it has a surge protection of some kind. A local hifi shop will usually be able to reset such problems.
Jan 05, 2010 | Harman Kardon AVR 335 Receiver
Can I conect harman Kardon avr 230 to apple tv
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
I'm looking some info on a diode that has cracked and the only thing about it is that its D788 in a Harmon-Kardon AVR 335
D788 is a zener diode rated 5.6V 1/2W, part #HVDMTZJ5.6BT. It shouldn't be too hard to find one of those. Good luck with the repair!
Jan 10, 2009 | Harman Kardon AVR 335 Receiver
My new Harman/Kardon AVR 154 has no sound and the blinking light cannot be fixed because I cannot get the OSD blue menu to come up on the TV screen from the remote.
Do you have your receiver output connected to the input on your TV? For example, if the receiver is in connection number 1, is your TV set to connection 1?
Dec 29, 2008 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Oct 19, 2007 | Harman Kardon AVR 100
148 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
