SOURCE: cold air all the time
one of you trampillias not working either a thin plastic pipe has come off or computer not working or a control switch so the flap is not opening up allowing the air to blow over the heater core rad .look under bonnet for a valve/solonoid with a pipe in and two or three out,sometimes this packs up which doesnt allow the vacumn through to open the actuators (trampillias)
SOURCE: 2000 Buick LeSabre heater only blows cold
the climate control thermostat is not opening the valve to let the warm coolant in
SOURCE: 99 Buick Regal LS dual climate control. No heat passenger side.
the motor for the passenger side
blend door is shot
Forgot to mention that I've been using the "auto" control setting. Most defrosters will run the compressor, but this problem occurs even without using the defrost setting. (I can get it to shut off with the "vent" button.)
