Question about HP Digital Projector Vp6110 Multimedia Projector
Hp vp6110 projector lamp issues
The lamp indicator light (small orange led) on my projector is on - and no image is projected.  I have replaced the bulb... but same problem - lamp indicator light is on, but no projection (the bulb does not even turn on)
  • Anonymous Dec 01, 2008
    bulb burned out as soon as i replaced
  • marvinhousle Dec 19, 2008
  • 146 Answers
SOURCE: HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Posted on Jan 05, 2008
  • 3422 Answers
SOURCE: Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Posted on Mar 22, 2008
Try turning up the brightness?
Posted on Apr 30, 2008
  • 4234 Answers
SOURCE: Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
Posted on May 08, 2008
Nic61
  • 1073 Answers
SOURCE: Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Posted on Dec 02, 2008
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Sony HS10 error lights
you could try a new lamp, some lamps fire, but do not stay on
Nov 09, 2007 | Sony VPL HS10 Multimedia Projector
No lit / projected image even with a new bulb!
Let me add...
I had one 3300MP and removed/replaced the bulb to dust off as it was overheating. There is a small metal like switch that resets the bulb replacement (physical switch - take a good look) -- This helped to reset the first time I did this, but doesn't reset the hours on the chip.
However, since this bulb was problematic for me, I have done this a couple of times and since has stopped powering the bulb now. So, thinking it was the bulb, I replaced the bulb, -- No good... So, thinking it was the projector, I bought a new/refurbished one on ebay -- tested the NEW bulb - NO GOOD. now I have TWO PROJECTORS, THREE BULBS and NOTHING THAT WORKS...
WHAT AM I DOING WRONG?
Apr 27, 2007 | Dell 3300MP Multimedia Projector
HP Digital Projector Vp6110 Multimedia Projector Logo
260 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
