Question about Microwave Ovens
I have a whirlpool microwave. Model GT4185sks-2. I turned on by itself. Afterwards, no heat coming from unit.
  • bmarks Sep 28, 2008
    Same model, same problem, no heating. The controls all work, and all voltages and resistances seem to check out. I suspect the magnetron but do not know how to verify.
  • Microwave Ovens Master
  • 9,098 Answers
When it's plugged in, does it still try to come on?
If so, it may have a failing keypad.
And if it ran empty for too long, it may have overheated and damaged the magnetron too.
I don't see a thermostat or thermal cutout mentioned in the exploded views and parts lists, but it pretty much has to have one.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
This is one case where that will come in handy.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
How can i change the light bulb in whirlpool microwave md. GT4185SKS-2?
Most standalone microwave ovens require removal of the outside cover to gain access to the lamp for replacement.
Oct 07, 2014 | Microwave Ovens
Fan comes on automatically
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
Aug 15, 2014 | Whirlpool Microwave Ovens
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
I have a whirlpool OTR microwave model MH6130XEB, and have lost all power. There is power to the microwave, but the microwave will not come on. Any ideas?
Call a service guy or if you are up to the project, remove the unit from the area and open it up.
Near where the electrical come into the machine.. there should be a circuit board that may look black because it burnt itself out.
Remove this board and replace it, Put back MW and turn it on
Jul 25, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
My ge profile microwave oven sometimes turns on when door is clos
hi and wellcome to FixYa this is a comon problem with the control unit for the microwave being damaged the buttons start to stop working more or few buttons at a time, there are companys that sell the front units seperate for these microwaves but can cost more than a new microwave itself , the unit itself is damaged by heat from the microwave or on rare accasions damp im sorry there is no other way to sort this apart from a new front control unit or a new microwave
Thanks Hope this helps a little
Feb 06, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool Microwave no longer heating
Sounds like the magnetron has failed. It is the magnetron that generates the microwaves that heat the food. If it or the circuit that powers it fails then it stops heating. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jan 10, 2009 | Whirlpool MH1170XS Microwave Oven
Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
