Question about Memorex Ultra Traveldrive - 160GB USB Hard Drive
Memorex ultra travel drive 120 - lost auxiliary power cable
I need to use the auxiliary power cable that came with the drive as it's not getting enough power from my usb hub, but can't find it, can you supply me with another?
  • 661 Answers
  • Somacompany_ Nov 21, 2011
    Looking for DC power supply .. Thanks
Computer doesn't see memorex ultra traveldrive, its a new computer and i lost the cd
to be detected by the computers need to install the driver if there is no need in looking on the web and download its drivers
Jul 23, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a Memorex Ultra TD v1.0 USB Device 160 Gb and has 120Gb free. The problem is that I can't copy a file that is 8 GB.
Right click your usb hard drive and press format. When the formating options menu pops up , under file system choose NTFS.
Mar 13, 2011 | Imation 120GB USB MEMOREX...
Do I need a seperate dc supply for my Ultra traveldrive usb 2 Why won't it install on my lap top.
> do I need a separate power-supply?
It depends. If the disk-drive inside the enclosure is a 2.5-inch "laptop" disk-drive, then it will draw the necessary electrical power through the USB cable. However, if the disk-drive is a 3.5-inch "desktop" disk-drive, it does require an external power supply.
Will it install on some other computer?
Dec 18, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Green light wont stay on on memorex traveldrive
The light signals a connection between the hard disk inside the Traveldrive to its case. If it fails that means that the hard disk is dead. The unit has died, junk it and buy a new one, hard disks can't be repaired.
Aug 25, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Device Manager says ok but can not open
Open Windows Help and Support.
Search for "assign drive letter".
Make sure the drive is using a drive letter that is already in use on your computer.
I hope this helps.
Feb 04, 2010 | Memorex Computers & Internet
80gb ultra travel drive is not recognized by computer when the hard drive is attaced to it. the main board is just fin that plugs into the usb but when I attach the hard drive to it the computer no longer...
One thing is if the drive draws more than the alloted .5 amp from the USB it the motherboard will turn off the power. SOME of these drives require a 5 volt external power supply. Some of them rob two USB ports to get adequate power.
Jan 15, 2010 | Memorex Ultra Traveldrive - 80GB 80 GB...
My Memorex 320 gb ultra travel drive is not working correctly; when I search a file, it finds it but then some of them don't open and I can hear a clicking sound on the disk like if it was searching for...
Sounds like the HDD is failing or failed. Try removing side cover to your PC (Switched off and unplugged from power supply) remove the CD cable / plug it into the ext HDD (Dismantled) boot into Windows.
If the PC cannot read the drive then it is damaged with loss of all files. If you can read it, I suggest you transfer backed up files to your PC before it fails completely.
Dec 30, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
How can I determine what space is left for use on my portable Memorex Ultra Travel Guide
Go to "My Computer" and find the page listing all your drives.
RIGHT click on disk of interest then LEFT click on the "properties" near the bottom of the little window that opened. The percentage used and othe info will be there.
Oct 21, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
Mar 24, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
I mistakenly deleted the file that allows the Memorex ultra travel drive 120 gb to open up. Can you help me
if you are using windows xp.search the driver in windows folder ...but if you write more clearly..
May 20, 2008 | Computers & Internet
Memorex Ultra Traveldrive - 160GB USB Hard Drive Logo
684 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
