Question about Kenmore 24032\24036 Top Load Washer
Kemore 20952 Top load
How do you get the cabinet off
    Novelist:
  • 177 Answers
Unplug the washer. Remember once you remove any panel you could be exposed to sharp edges!
under the control panel are typically two screws, remove these.
the control panel should slide forward and then flip up.
Now on the top are two clips, one on each side, take a screw driver and slide them out, it takes a little force.
you may have to unplug a couple wires and or remove a hose.
Now the cabinet will come off it is pinned at the bottom front.
Posted on Jul 10, 2008
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
Feb 28, 2015 | Kenmore 24032\24036 Top Load Washer
My kemore 110.24422300 will fill and drain but no agitation(sp) sorry.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24422300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor
coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6
inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to
put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Your washer is a direct drive model. It uses a coupling to transfer power from the motor to the transmission. The pump mounts on the motor also. If The coupling can simply fall apart with age but usually a comforter or rug will finish it off. To replace the coupling you must remove the cabinet. I have the directions with manual and repair videos: HERE
Mar 17, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
How do I lift the top of a kemore 90 series washer
you don,t.unless its over 20 yrs old.the whole cabinet comes off.console folds up and away then 2 clips hold the cabinet to the frame
Jan 15, 2010 | Kenmore 24902 Top Load Washer
Kemore 70 series make a load Squeaking noise when on spin.
I would guess it is a belt issue. You may have a worn drive belt that is making all the noise.
Dec 16, 2009 | Kenmore 24712 Top Load Washer
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Washer case fitting onto frame
Some will just fall right back into place then there are those like yours that well, prayer never hurts.
I always open the top so I can see what I'm doing.
The cabinet should be leaned back about 45 degrees so the front lip goes under the front of the washer frame. Keep it at a 45 angle while you push it forward with your foot. The front of the washer frame must be off the floor at least 2-3 inches. Some that have the legs run all the way up will require raising either with the legs or a piece of wood.
Once you have the front of the cabinet under the washer frame, hold pressure with your foot and lower the cabnet down on the frame. The back of the frame has a metal *** sticking up that must go in the slot on the cabinet. Some times it will require doing one side at a time to get them in place.
At this point you should be able to push the back panel back into place. Sometimes one side at a time, sometimes I will go ahead and push one side in and put the bracket in then do the other side.
Hope this helps. I'll be pray'n for you.
Jan 24, 2009 | Kenmore 24902 Top Load Washer
Kemore waser leaking
center front ,,pump is bad ,,if you need help changing,,post question
Dec 26, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
208 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
