Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Gld5860l00ss QuietPower2 water leak
The dishwasher is leaking small amount of water underneath the machine. I don't know how to pull out the machine to look what is causing the leakage. Got any ideas?
Thanks,
Ruben
  • spye1 Nov 27, 2008
    Brand new unit. First run and it leaked out the front. Adjusted the level so the unit tilts back slightly and it still leaks. Still looking for a fix.
    Problem Solver:
  • 8 Answers
Did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Posted on May 01, 2009
My dishwasher has leaked a smal amount of water from underneath
Jackie, It is probably a seal(gasket) leaking, you may want a service tech. to have a look.
Mar 09, 2016 | Hotpoint 24 in. FDW60 Free-standing...
Small amount of water at bottom of machine after washing dishes
Hi Matthew!
Pull the dishwasher out and check for leaks at the hoses connection and tighten any loose one or call in for service.
Oct 28, 2015 | Dishwashers
My Danby 1805 portable dishwasher leaks from underneath only when the water is being pumped back from the washer to the sink. My repair technician was not able to find the leak by looking from underneath...
Your pump may be cracked or a drain hose may have a hole. Also check the dishwasher housing not the cabinet that you can see I have seen small holds due to defects in the plastic that the housing is made up of. Of time with heat and moisture these hols may appear. Look for small crackes in crevices. They are hard to detect once the cabinet is removed start the dishwasher and have flashlight to see exactly where water is coming from.
If you have anymore questions please comment me back.
Jul 28, 2011 | Dishwashers
My brand new still in the box dishwasher was leaking in my truck and now is leaking on my kitchen floor. Is this normal?
No, this is not normal. Sometimes a unit gets frozen (cold) and cracks plastic. Sometimes a hose gets pulled off.
The amount of water allowed to leak needs to be zero.
Pull the unit, get lots of light, mirrors possibly, and find what is leaking... Once you identify where the water is coming from, you will know how to proceed.
Zero water leaks.
Mar 22, 2011 | Kenmore Dishwashers
Water won't come into the dishwasher
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
Apr 21, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Hear the motor running, no water in dishwasher
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Feb 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
The cupboard next to dishwasher becomes full of condensation during drying cycle
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Sep 03, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
339 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
