Refrigerator and freezer are working fine. However, when the unit is running the outside front sections of the top and side freezer area are hot to the touch. Is this a serious problem?
Its normal, the heat is coming from the condenser which is integrated within the freezer cabinet and is completely out of sight.
Mine is the say but my temp between the freezer and refer are 122* F. It was never like that before, just a mild warm temp. They replaced the compressor/condensor twice, the cond fan AND the evaporator fan and it's still 122*F and yes it's all been cleaned
Hi
If the unit was off for a while then more heat is inside the freezer after having it off for a while. That heat gets moved out to your condenser coil. Most freezers today don't have fans to force that heat to the outside air, they run that heat through the outer cabinet and it naturally travels to the cooler surrounding air. If there is no rear cover and no fan motor near that compressor this is how yours is designed. Just give it sometime and it should be fine. However it should be warm to the touch but not so hot you can't. And also depending on how long the freezer is running and how warm it is where the freezer is will affect how hot the outside is. The reason the outside of the freezer is hot is because that's how the freezer releases its heat from the refrigerant. The longer it runs or the harder it has to work the more heat it has to hive off. So unless the freezer is not cooling there is nothing to worry about.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
freezer seems to be working fine
