Question about Maytag M7Y15F2A Air Conditioner
3 coils freeze up!
After topping up the coolant, the 4th, 9th and 10th coil still freezes up...
  • 31 Answers
Sounds as if you have a restriction in the line
Posted on Nov 17, 2008
The coils jeep freezing up I have cleaned the filter
usually means Freon charge is low, you might have a leak..... also, filters don't catch everything. over time what gets past the filter can be trapped in underside of the evaporative coil on top of your furnace..... outside condenser coils may be caked with debris, improper air flow threw coils can produce liquid Freon back to evaporative coil causing it to freeze..
hosing the condenser down will resolve freezing up too
Oct 04, 2015 | Filter Heating & Cooling
Drain line on rheem raka037jaj cenyral air unit not draining and cois freeze up
Hello, coils will freeze either to low airflow or low refrigeramt charge. Make sure filter, blower wheel and evaporator coil are clean. If they appear clean there is a low refrigerant charge.
Jun 06, 2012 | Heating & Cooling
The front of the unit behind the filter freezes up. Worked flawlessly for weeks but freezes up. Cleaned the filter several times but continues to do so.
the reason for the coil (behind the filter) to freeze up is 'low air flow' over the coil, which is usually caused by a dirty filter AND/OR the coil itself.
Be sure the coil is clean and not clogged up. Shine a flashlight into the fins and be sure it's clean.
If it is clean then you need to look at the fan motor. Is it blowing correctly? Is it cutting off at times?
Low air flow across the coil is the main problem with coils freezing up, although less likely is a 'low refrigerant charge.'
I would make sure the coil was clean and the motor was blowing air across it in the proper manner.
Aug 05, 2011 | Haier ESA3109 WallWindow Air Conditioner
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
you need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
Aug 25, 2010 | Honeywell Heating & Cooling
My air condtioning unit is a GE unfortunately I can't se what btu but ev ry our the coil freezes and its spitting out water. Room size.
clean the coils its freezing up because the air flow is restricted because of dirty coil or filter after cleaning the coils and it still freezing up then it will need some refrigerant aka freon
Aug 19, 2010 | GE Built-In Room Air Heat Cool Air...
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
Coils freeze up
Make sure blower is running at the proper speed, if it's running to slow do to bad bearing or capacitor, the coil will freeze up.
Check evaporator coil and filter to see if they are dirty if they are then the coil will freeze up
Check the charge if it's low on refrigerant the coil will freeze up.
If your not sure how to check these things, then you should have a HVAC company, check it out for you.
Jun 03, 2010 | Whirlpool ACC108PS Air Conditioner
Coleman deluxe blend air ll it starts up
The blowing fan is not rotating at the rated speed. Check the fan capacitor and replace.
Check motor also if the capacitor is not at fault.
May 27, 2010 | Heating & Cooling
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
Maytag M7Y15F2A Air Conditioner Logo
54 people viewed this question
Top Maytag Heating & Cooling Experts
Claude Kayser
Claude Kayser
Robert A. Watson
Robert A. Watson
Dave Larson
Level 1 Expert
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
