Question about Pioneer AVIC-D3 Car DVD Player
Reset the time
How do i reset the time? i had to put in a new battery and i need to change the time back. i heard to reset it but i dont know where the reset button is
    Problem Solver:
  • 5 Answers
There is no reset button for the time. The stereo gets the time from the GPS antenna. If you are parked in a garage it will not work. the only thing that you usually need to cange is the daylight savings time.
Posted on Jul 12, 2008
I put a new battery in my 94 geo prizm car and it started right up but then I turned it off and it wouldn't start back up and I heard a clicking noise everytime I tried to turn it on, what could be...
can you tap whit a small hammer on the starter tree times,if he starts good,you have to change a new starter.clicking sound can be the coils from starter that dont open.
Jul 07, 2013 | Cars & Trucks
Need to reset passcode on skylink g5 garage door opener
G5K Reset
  • Remove the batteries for 2 minutes
  • Remove the T-shaped cover at the back of the keypad
  • Below the ABCD switch, there is a 3 prong jumper
  • Move the jumper from [Left & Centre setting] to [Centre and Right setting]
  • Put batteries back in
  • Enter [7 6 5 4 #] (2 slow beeps must be heard, if not, repeat the process)
  • Move the jumper back to [Left and Centre setting]
  • Wait 2 hours and the MPIN will be [0 0 0 0 #]
If the reset did not end according to my instructions, do it 2 or 3 times more. Remember, the battery has to be out of the unit for at least 2 minutes before doing the reset.
To change the PIN:
  • Enter the current PIN, (factory default PIN 0 0 0 0), press *
  • Enter new 4 to 6 digit PIN, press *
  • Enter new PIN again, press *
  • You should hear a long beep
Note: You only have 5 seconds to complete the task otherwise it won't work. If you failed to complete it, simply do it over again.
For example, if you are changing the PIN number from 0000 to 123456, enter the following sequence, 0000, *, 123456, * , 123456, * .
Keep in mind that you need to do this within 5 seconds only.
If confirmed, the backlit LED flashes and the unit emits a long beep.
Jun 10, 2012 | Home Security
Clarion vz401 unlock reset?
ok i have a vz401 and it was locked out so what worked for me is.
hold the volume down button then push the power button after you are holding down the volume button.then if you dont know the code put in 4356 it worked for me
Apr 05, 2012 | Clarion VZ401 Car Video Player
I have the linksys router WRT54G and i would like to put my own password so no one else can use my internet. only thing that is giving me a problem is that when i go on the web browser and put the code i...
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
Jan 25, 2011 | Linksys Wireless-G WRT54G Router
How do I reset the "HOLD" button when pushing to reset does not work? My Grandaughter got it stuck, so I am not sure what they did to prevent the reset by simple pushing the button again.
Make sure the button is up and disconnect and reconnect the battery this should reset everything and do not give car any gas when starting it may want to shut off until the cars computer gets use to the air and fuel intake.Just let it run.Try to connect positive terminal as fast as possible when connecting to avoid a short cicuit the less sparks emitted from the battery the better.Wich means dont sit there rubbin the posittive wire on the battery.Reconnect after 1to2 minutes and hope for the best if this dont work you probably broke the hold button.Not recommended but take at your own risk.Only reason im saying that is because somtimes you can really damage the computer if you dont do it right.I know this because I have heard off people causing damage to there computer but I have never had a problem it's just like changing a battery no different.Just take yours out wait 1to 2 minutes then put it back in.Good luck
Jan 15, 2010 | 2005 Chevrolet Aveo
Password lost ,clear the Bios
this would and could be done by shorting out the bios pin or taking out the battery inside or pay $65 bucks to have a locaL tech do it for you simply put the device needs to be opened up a tech would have a device to reset it without opening the unit of course your ownership will need to be proved at that point not saying you ripped of a poor kid or anything but just putting that out there :) thanks have a happy new year and please rate your fixya experience!
Dec 30, 2009 | Acer TravelMate 245XC (LX.T3006.069) PC...
Reset button for breaklights
never heard of it ,a reset button for the fuel pump yes .Try a new switch
Dec 27, 2009 | 2007 Kia Rondo LX V6
Display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
How to turn off the change oil light
1. Turn the ignition to ACC or ON and turn the radio off.
2. Press and hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
3. Press SEE PSCAN up or down arrow to scroll through the main menue.
4. Scroll until the OIL MON appears on the display.
5. Press the 1 PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
6. Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until the EXIT appears on the display.
8. Press the TUNE DISP button to exit programming. A chime will be heard to verify exit.
Enjoy!!!
Jun 17, 2009 | 2005 Chevrolet Monte Carlo
Stuck on MITS screen, will not start windows mobile
try a hard reset i tell u how:
1.press and hold the reset button
2. dont let go yet! push the power slider down at the same time
3. let go of the reset button, wait a few seconds then let go of power slider and it should work
else u may need 2 get a new phone or try a firmware upgrade
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
Pioneer AVIC-D3 Car DVD Player Logo
356 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
