Question about Toshiba 36A50 36" TV
Analog odr Digital?
Power supply is going. Picture shrinks and if you bang the top of Tv picture fills out fully. With all siginals going digital I would like to know if it is analog or digital. Otherwise I will get rid of it.
  • Grandpa66 Jul 10, 2008
    Thanks for helping me make a decision. You guys are great.
  • 51 Answers
The problem you are having is a loose solder connection on vertical ic,easy fix only soldering vertical ic.tools you need solder iron and solder. but yes your tv is analog and will require a digital converter.
Posted on Jul 10, 2008
Is it analog or digital?
If it is a standard CRT TV unit it will be analogue only. If you want it to display a picture from a digital signal you will need to buy and connect a digital set top box to the TV. The set top box then picks up the digital channels through the antenna and displays the picture on the TV set. You will need the basic connections on the back of the TV to be able to connect a set top box and many older TVs do not have them..
Dec 26, 2015 | Televison & Video
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Digital picture freezes for split second every now and again
U have Cable,Satalite,or Teleticom Siginals ur incoming signals 99.999%.Digital antena about 95%.Roof antena about 90%.Indoor Analog antena about 89%.Yes the signals is varies u will have freezes,not ur tv
Oct 15, 2009 | Televison & Video
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Jan 03, 2009 | RCA 20F420T 20" TV
32 Toshiba TV no picture / bad pciture
Hello Suzid, It looks to me like you have a possible power supply issue (poor brightness on screen, shrinking of the picture, and initially no picture) This problem may put you in danger of electrical shock, so I would suggest that you not try to repair this set yourself. I would suggest that you take the television to a television repair shop.The power supply issue could be a low power or a high power supply problem.
Oct 03, 2007 | Televison & Video
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Toshiba 36A50 36" TV Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
