Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Solid ice on coils
On one of my delonghi PACL90 models, there is a solid sheet of ice forming on the coils between them and the filter. I had it turned off and melted it with a hairdryer, drained it by openning the two drain tubes at the bottom, waited 12-14 hours and then tunred it on again only to have the ice form again. Is the unit gone or is there a solution?
    Novelist:
  • 121 Answers
Sounds like the compressor may not be shutting off, that may be the sensor (t-stat) or a freon leak, but usually only a partial part of the coil freezes up if it was low on freon an would not be cooling properly. if under a year old call manufacture. if 2-5 years old may still be under warranty if the repair is a freon issue. if its the sensor your looking at about 40. fot the part and roughly 75-95 for labor (depending were you take it too). check your purchase date and read your warranty 1st
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL. 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
EMAIL customerservice@allbrandsapliancerepair.com
we are a authorized servicer for delonghi if you have any aditional questions thank you
Posted on Jul 11, 2008
Evaporator coils are freezing up. I took off the side cover and it is a solid sheet of ice covering 90% of the coils.
Hello, ice will form for one of two raesons, either low airflow or a low refrigerant charge. Start by checking the filter to make sure it is clean, then check the blower wheel and make sure it is clean. If the unit is clean then the unitnis low on refrigerant and will require a hvac tech to come out and recharge the unit.
Jul 10, 2011 | Heating & Cooling
Ice formed around the filter area last night. Unit quit cooling.
Ice forming means you have your AC set at a temp that is too low. Of course it cannot remove the heat from the air if no air can pass over the coils. There is very high humidity in the space you are trying to cool ... slow down a little on your cooling process.
May 26, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Where can i purchase filters for my DeLonghi AC?
Well I found this page http://www.yourspares.co.uk/proddetail.asp?prod=1688461 and you can get the filter there for £22.25 , which is about $35.00. I simply took the part number EL7351031200 and searched for it. That's the cheapest one I could find though. I read that it's a 3M filtrete filter, and, knowing me, I would just buy a cheaper, larger filtrete filter at wal-mart, cut it to size, and glue it to the plastic frame of the old one. I hope you also know that you can wash the filter in warm water until it wears out.
Sep 25, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Ice is forming on the coils - delonghi dehumidifier
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant or Blower speed to low. If the blower doesn’t run when you turn the switch to on then you need to check the blower out, especially the capacitor.
Aug 01, 2009 | Dehumidifiers
PAC L90 LT thermostat not working, unit icing over
No that would be either a dirty filter/coil ir low refridgerant if it's freezing in cooling mode.
Clean/replace the filter, clean the coil and if it keeps doing it, have a technician who is EPA certified for servicing systems with refridgerant to look at it/add refridgerant.
Mar 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Ice in the unit
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Left house for a while with unit running and when I returned little or no air was emmiited from unit, and when I removed back cover, solid sheet of ice!
Sounds like you have a coolant leak or the thermostat is malfunctioning.
You need to have the freon checked first to see it is not low.
This one reason that will make it freeze up .
let me know how much freon it took.
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PACL90 MODEL
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Aug 17, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac l90 air filter
Call 800-865-6330.  The white accordion 3M Filtrete filter is $37.95, and is NOT available on the Delonghi website.
May 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Don't know where to buy eletrostatic filter
you have to purchase it from the delonghi website for 10.95. I wish it was available in stores but...it's not ! ergh.
Apr 22, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
311 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
