Question about HP LaserJet 1100 Printer
Paper feed feeds 3 or 4 paper at once
  • 42 Answers
Your friction pad needs replaced
P/N RF5-2886
Remove toner cartridge and protect from light
carefully pry off two blue base locks.
remove rear cover screws and pop off back cover
facing front of printer open cover remove paper feed tire and note position of driveshaft {2 screws}
engage paper feed cam solenoid with small screwdriver and using main drive motor spin release cams to lowest point of resistance
carefully pry separation assembly from printers frame and install new one noting spring on rear of assy'
when installing new pad if you have difficulty rotate cams via main drive motor to allow more clearance.
reassemble and be careful when installing feed tire on driveshaft .
Posted on Jul 30, 2008
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
My dell 2350 dn feeds to much paper causing jam
Step 1: Try fanning the paper at the feed edge before placing it in.
Step 2: Ensure that the paper is placed in with the edge curl up. When holding a bunch of paper between two fingers, the paper will naturally have a curl to it. It should be placed in "happy" (Edges up).
Step 3: Inside the printer's paper tray and where the feed mechanism is, locate the feed rollers and static feed pad. These will all be rubbery or "foam"-like. They should always be slightly tacky when rubbed against, however paper dust will eventually cause them to become slippery instead. Rubbing alcohol can be used to clean them with care and a Q-tip and recover the slightly rubbery, tacky feeling, thus resolving misfeeds.
Mar 28, 2014 | Generic Laser Compatible Dell 2330 2350...
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Hi my this model of printer is not pulling the paper..how to solve it?
Hi, Manually you can feed the paper right? top feed or front feed. LQ 300 has a sensor for paper feed, if it cannot feed paper automatically there could be something wrong with the paper feed sensor. Sensor of which is just a switch that once the paper pass, it will trigger the switch. If you can open up your printer, you can check the switch if still working. If you manage to locate the switch take out the switch and have check by ohmmeter tester to check the continuity. It sound technical but you can ask help.
Jun 21, 2011 | Epson LQ 300+ Matrix Printer
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Paper feed problem.
I have just removed the panel where the power and USB cable lock into. It's a case of 1 screww from the rear and 2 catchs underneath the printer. From there you should be able to see the mechanism for the roller, a set of small white cogs. below that you should be able to see a very small spring which is acting as the pressure. Mine was still attached but as you say was pulling no pressure on the roller what so ever.
Solution:
Find yourself a large-ish rubber band and slip the band over the whole mechansim. Best way is through the paper feed slot, slip it over the roller and then move it through to the area where you removed the panel. Position the rubber band as far down the cogs as possible, don't worry the cog casing prevents the band interfearing with the cogs. Now pull the band reasonably tight and with the other hand test the pressure of the roller. Adjust till you feel OK with it. Now put the panel back in with the end of the rubber band trapped and poking out from the panel behind the printer, holding it in place. Redo the screw and give it a try.
My first attempt found it a bit too restrictive and feeded to sheets at a time but adjusted it once and its back to normal. I know its a bodge but its a cheap one and it uses a rubber band, just how I fixed my Punto's windscreen wiper, £120 part or a rubber band once a month... Mmmm...
Jan 22, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer
I have seen your issue on the paper feed for your printer. Well, I am thumu from india-Hyderabad. I would like provide my solutions on the issue.
This issue could happen due to the following below causes:
1. If you are not using the recommended Paper type for your Printer
2. If you feeding the Paper incorrect.
3. if paper type selected in the Printer Properties and the paper type that are trying to feed are mismatched.
4. If there is an issue with Paper Feed Rollers of your Printer. Or some times, the issue could also happen if there is some dust on the paper feed rollers.
5. If there is an issue with Printer software might have got corrupted.
Try below solutions :
1. Check whether the issue happens with all applications or not.
 If it happens with all applications, then we need to troubleshoot further or if it happens with Particular application like MS-word, then we need to check the Print settings.
2. Make sure that you are using Correct and recommended Paper type for Printing and same paper type is selected in the Printer Properties.
3. If the issue still happens, then please disconnect the Printer from Wall outlet and from Computer, try to clean the Printer paper feed rollers . Please look in to Manual or Instruction set that is given with Printer to clean Paper feed rollers.
If the issue still happens, then I suggest you to opt and go for online Chat Support  for your Printer. They can help you with much more information.
For your convienience, I would like to provide you web link for Online Chat Support for Lexmark Printers.
http://support.lexmark.com/cgi-perl/support.cgi?ccs=229:1:0:520:0:0&
Once if you open the web page please click on the chat Support . This will get you to live Chat Support agent.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com if you need any further assistance on any issue. I'll be glad to help you.
Oct 02, 2007 | Lexmark X73 All-In-One InkJet Printer
HP LaserJet 1100 Printer Logo
148 people viewed this question
Seeker5211
Seeker5211
