Question about Black & Decker String Trimmer Cordless 12" 18V
Weed Eater Model RX70
The pull cord has broken on my weedeater. How do I put it back and how long should it be? Is there a manual out there for this as the company seems to have gone out of business.
  • 1 more comment
  • Anonymous Aug 30, 2008
    My pull cord is stuck.
    I am afraid the spool may be wrapped around on the inside or caught in roll.
    Please advise how to clear / free pull cord
  • Anonymous Sep 04, 2008
    TRIMMER WILL NOT START
  • Anonymous Nov 30, 2008
    Pull cord spins but does not start unit
    Problem Solver:
  • 9 Answers
You should thke it to a small engin repair it wont cost much and if you get the spring unwound it would be verry diff to fix i have fixed a lot of pull ststers u must be carful with the spring linth of rope is usely a full spool
Posted on Jul 30, 2008
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
Im having truble puting the starter cord and springs back in my husqvarna weed eater 128ld
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Apr 22, 2016 | Husqvarna 128 LD Weedeater
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Apr 10, 2010 | Poulan Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Homelite weed eater model rx70
you can go to this website and find your trimmer manual. hope this helps.
http://www.homelite.com/service_support/order_parts
Tobaz
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Black & Decker String Trimmer Cordless 12" 18V Logo
571 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
EugenesDIYDen
EugenesDIYDen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
