I am trying to get pictures from my memory stick and place the pictures on my computer is there a way to do that
  • 31 Answers
Hello :-) and yes there is a absolutely way to do that. You must stick it into your computers USB port. then go to your main screen and click "My computer". Then you will see one icon that says removable disk (E:). You will click on that and then you will see your pictures or a file in there that will lead to your pictures :-).
Posted on Jul 10, 2008
    Problem Solver:
  • 30 Answers
You computer must contain the proper port for any camera, if you are using a USB flash drive, you simply connect it to any USB port, if however it is a camera memory stick you will need to buy the external hardware that allows you to extract the pictures from the memory stick, this piec of hard ware can be found at any computer store.
I can see all my pictures that I took on my camera but when I put my memory stick in the computer and at Walmart photo lab they are on my memory stick..why?
Trying taking the memory card to a computer and looking through it for the photos. Take them off and put on pc. Then format memory card. Place memory card back in camera and take a picture. Then put memory card back in pc and take original photos and drop into folder that has new picture you took. It should work by noe if not then get a new memory card. Then try again.
Jul 05, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 14, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Trying to download pictures off the computer through ubs memory stick not working
You must Identify the letter of the drive associated with the memory stick (E:, F:, H:, etc) - through the MY COMPUTER section, format your memory stick by right-clicking the correct drive number. Once formatted you should be able to drag and drop your pictures from your computer to your memory stick.
Apr 19, 2009 | Cameras
Photo problem. sony cyber-shot 10.1 MP silver touch screen
Take out memory stick, connect camera with PC, go to Removable Disk, go to folder and copy that picture. Simple !
Jul 31, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
I think I replied this post! Take out memory stick and connect camera with PC without memory stick. Go to pic folder and copy it. Simple :D
Copying computer pix to memory stick
The resolution is probably incorrect for the camera LCD. try changing their size to a standard size like 640x480 with a resize program.
Jul 13, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Importing data from stick to computer - deleting data on stick
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony DSC-P71 Can't Transfer Pics from memory stick to computer
I have the same problem .Ican see pictures on LCD but thet stick is not recognized by computers. we tried at wal-mart and other shops too. please help me. these picturs are very precious to me. Thank you.
Apr 07, 2008 | Sony Cyber-Shot DSC-P71 Digital Camera
Computers & Internet Logo
49 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
