Question about Casio Watches
How to remove links from CASIO S-1060L watch band on wv-300DA watch.
  • Anonymous Dec 10, 2008
    I can't delete those links.
    I tried to push with a big niddle but it didn't work.
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
escapement
  • 2334 Answers
SOURCE: remove watch band link
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 27, 2009
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Apr 01, 2009
escapement
  • 2334 Answers
SOURCE: need to adjust length of watch band: Casio WV-57H
Check out my TIPS here and you will find out how to do that
Posted on Feb 05, 2010
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
Where can i get a resin watch strap for a Casio Wv-200U-1AVEF
Most department and discount stores that sell Casio watches will carry a general assortment of replacement bands for those watches. However, your model takes a somewhat specialized band that may not be stocked by these stores. Instead, if you're looking for a local source for a replacement band, you might need to visit a "quick watch repair" kiosk or store in your local shopping mall or visit a jeweler who sells Casio watches. Often, both of these types of businesses keep a more comprehensive selection of authentic Casio bands in stock.
Replacement bands are also available online. For example, just because it was near the top of the Google search results I received, this web site has a wide variety of Casio bands, along with suggestions of the watch models to which they go. I have not ordered from this web site, and I have no affiliation with them (I actually think some of their prices are on the high side), but it's one of many online sources for the watch band you need:
http://www.casiosalesandservice.com/istar.asp?a=3&dept=cwband
Good luck finding the band you need at a decent price!
Jun 01, 2011 | Casio Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    I need to shorten the metal link watch band of my Casio Model 2747 watch.
    I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
    I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
    Thanks,
    Steve Zansler
    Dec 31, 2009 | Casio Watches
    Adjust-a-Casio-S-1087DY-Watch-Band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Watches Logo
    265 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
