Question about Quorum Ceiling Fan - 138880
Ceiling fan motor hums but the blades do not spin
I checked all the wiring and everything is hooked up and tightened, blades spin freely by hand and does not start after a push then power.
  • bejt61 Oct 16, 2008
    The same thing and the motor gets very warm/hot
Pranavendra
  • 16 Answers
SOURCE: 42" ceiling fan
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Posted on Nov 29, 2007
ccanni1028
  • 10 Answers
SOURCE: ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Posted on May 01, 2008
  • 68 Answers
SOURCE: ceiling fan turns slowly
If you've had it for a few years, the bearings are probably getting bad (dry).
Always start a fan on high---then go to the speed you want, only the high speed windings will handle start-up.
Posted on Apr 28, 2009
  • 10865 Answers
SOURCE: new ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
Posted on May 16, 2009
  • 8404 Answers
SOURCE: the motor wants to run but the blades are
Spray the bearings with a little WD-40
Posted on May 16, 2010
I have a Hampton Bay ceiling fan Model BC552. light works, but fan does not. there is vibration (hum) when fan motor is switched on, but fan blades do not move. Blades rotate freely.
Start up capacitor is likely bad. That's the rectangle thing in the bonnet with two wires. If you replace it, replace the on/off switch at three same time.
Oct 10, 2017 | Hampton Bay Dryers
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
Why don't fan blades rotate?
Sadly Hunter doesn't want people dismantling their stuff and replacing broken or burnt out pieces. They'd rather you buy a new one. If the motor has burned out which is possible a solution depending on how handy you are is simply hunt down a similar replacement and reconnect it.
Make sure the new motor has the exact same leads and connectors as the old one had as some Hunter fans have more than two leads. The model I have has four leads: a black, a white, a green and a red as my model has integrated lighting controls by passed by the motor.
I bought a simple blower motor with the same rating only two wires and with a bit of solder and wire I hooked up the motor and lights separately. The new motor is much faster than the older one so I had to add a tiny 1-way 500 watt dimmer switch to manually turn down the speed.
Aug 30, 2015 | Hunter Dryers
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    I just installed my ceiling fan with lights. The
    Do the blades spin freely? If not, something may have fallen into the motor, jamming the blades. That would cause this. Also, make sure there is a good connection at the wire that feeds power to the fan motor (usually black, blue is the light) Good luck.
    Mar 25, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
    Model # yg2047b. I had this fan installed in June, worked fine,now it hums..what could the problem be?
    If the fan does not spin and the motor hums, you have a stuck rotor. It may be due to bushing/bearing alignment problem or a lubrication problem.
    Try to spin the fan blade manually. It should turn freely, otherwise the rotor is stuck. Remove fan blade and put few drops of lubricating oil on the bushings/bearings and manually turn the shaft to free it up. Alignment of shaft and bushings/bearings must be after lubrication is done and the rotor is still stuck. Move the shaft up and down and side to side until it smoothly spin when manually turned.
    Aug 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    Ceiling fan power
    Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
    Quorum Ceiling Fan - 138880 Logo
    651 people viewed this question
    Top Quorum Dryers Experts
    Are you a Quorum Dryer Expert? Answer questions, earn points and help others
