Question about Motorola Mobility RAZR V3
Change number of rings
Is there a way to shorten the number of rings before voice mail picks up?
Thanks for your help!
  • Realitychk Aug 16, 2008
    My razr rings so many times (6-7)before vm picks up that people will hang up and either redial or just hang up and leave no mssg. Anyone know how to shorten the number of rings, like to 4 like most phones?
  • Linda Moore Apr 29, 2013
    I have a Samsung Galaxy note that rings around 14 times before vm picks up using pinger...would like to know the answer for my type of phone.
Ther is no way to shorten the number of rings.
Posted on Jul 10, 2008
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Jan 07, 2008 | Lucent 1872 Corded Phone
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My phone only rings 3 times then stops how can i make it ring longer thanks brian
When it stops ringing, the caller goes to your voice mail, right?
If so, then you need to contact your phone company and have them change your "Ring Cycle" -- that's the number of rings before the voice mail system picks up.
Some phone companies have a way for you to do this yourself from their website, other require that you call up the customer service line. Either way, the thing you want to adjust is your voice mail ring cycle.
Sep 27, 2010 | Doro Cell Phones
How to you change the number of rings before voice mail kicks in?
Before the Auto Attendant picks up or an extensions voicemail?
May 20, 2010 | Avaya Corded Phone avaparp18d
Voice mail
Check your voice mail settings are enabled for no anwer/ busy.
Then check your voice mail number is entered correctly and not disbled by phoning your voicemal
May 12, 2009 | Motorola Mobility i870 Cellular Phone
Phone rings 10 times before voice mail picks it up, how do i change it?
In my VZ wireless I have to change it by calling tech support.
Your carrier may not offer it. Since your phone needs to be found, the number of rings you hear and the intercept time may be different. The stock answer is "if your cell is close to a tower it will work after X rings".
Carl
Apr 15, 2009 | Lands Phones
I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Apr 12, 2009 | Lands Phones
Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Jan 16, 2009 | Avaya Corded Phone avaparp18d
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Motorola Mobility RAZR V3 Logo
165 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
