Question about Genie Aire PACR12 Air Conditioner
Ventless use of Genie model KY-32U/11156
I want to use this portable AC in a room where I cannot vent it out the window. I was told this was possible but have never done it before (the machine is from 2001). How exactly do I do this? Obviously I would still need to empty the container where all the condensation collects, but what else?
I need to know this before 10 AM Thursday PDT, so would appreciate a prompt reply.
Thanks in advance--
Roberta
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: On soleus ky-32u air conditioner,
The water tank is full the solution is to Empty the water tank.
The water tank is not installed correctly.Just install it correctly.Completely re-insert the water tank again
See page no 14 in the manual.
click here to download the manual.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
  • 47630 Answers
SOURCE: i have a genie aire portable air conditioner model pacr12-ge
check your local hardware
Posted on Feb 09, 2015
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
I just bought a 30K ventless wall mount heater and have a 24X30 insulated garage. I set it on 2 and it keeps it about 60 degress but the smell burns my eyes and stains my clothes. It's brand new. I have it...
You need to ventilate this area while the units running! This is potentially a lethal situation!
You are competing with a flame for oxygen and breathing the carbon monoxide gasses
from the heater! Both unacceptable scenarios! you can easily die in this environment!
I cannot stress this enough! You need to open a window or crack the door enough to allow air to circulte and gasses to vent out and escape, If the burning of eyes is really bad your unit may not have sufficient combustion air, I can t tell you without seeing it precisely, you better vent that room though!
Dec 24, 2010 | Reddy Heater RLP100 Portable Forced Air...
Determine venting requirements
When you initially unpackage the microwave oven it is already set up for RECIRCULATION mode (which is VENTLESS). However, since the unit recirculates air rather than exhausting it out through the wall or roof, it usually uses a couple of small charcoal filters behind the upper grille and mesh filters on the underside that have to be changed or cleaned periodically. These filters will accumulate grease and dirt over time and should be periodically checked in order to maintain proper ventilation and air flow. Information pertaining to the location and care of the filters is explained on Page 4 of your Owner's Manual.
NOTE: If you wish to convert to a VENTED system, the instructions are listed on Page 4 of the Installation Guide.
If you do not have either manual you can obtain copies at managemylife.com. Just type in your model number as "GMH3174XVB" and you will find the manuals listed in a .pdf (Adobe) format that can be printed or downloaded for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 25, 2010 | Microwave Ovens
Need window air conditioner to fit window 23" wide. Studio apartment main room is 13'X17' with kitchen 6'x17' and walk-in closet and bath 5'x17'. Would like a kenmore and quiet while in operation.
Hi; Try purchasing an up right portable ac unit. Then all you need to do is vent the hot air tube out a convienant window or dryer duct. Needs to be at least 12,OOO BTU. I size my installs to 400 sq. ft. per ton(12,000 btu)
Jan 18, 2010 | Kenmore 75085 Air Conditioner
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Sunbeam KY-25 portable air conditioner not working.
Mine works but with a bad exhaust fan, want to sell yours?
Apr 26, 2009 | Soleus KY-25U Air Conditioner
Genie Aire PACR12 Air Conditioner Logo
477 people viewed this question
Top Genie Aire Heating & Cooling Experts
Michael Youngman
Michael Youngman
Ronny Bennett Sr.
Ronny Bennett Sr.
ray gallant
Are you a Genie Aire Heating and Cooling Expert? Answer questions, earn points and help others
