Question about HP Pavilion dv9000z Notebook
Downloading problems when i want to download executable files, i always do have problem, either it is corrupted or cannot download. please what do i do?
  • HP Master
  • 12,061 Answers
OK get yourself a download manager, like Flashget, and use that OR use Firefox.. it has one built in OR get IE7 Pro, it will install a DL manager...
Also check ya antivirus etc is "Allowing" exe progs to be dled
Posted on Jul 15, 2008
PDF file corrupt, how to repair it?
There is a universal solution of your problem: PDF Repair Toolbox - The tool reads corrupted PDF files and saves all recovered information to a new file for Adobe Reader/Adobe Acrobat.
Mar 19, 2016 | Microsoft Office Professional 2007 Full...
Break in operation file is corrupt
the file you are downloading is corrupted on the file server, or there is a malware on your computer that is infecting the file as it is downloaded.. and hence the software is not able to execute properly.
call 1-877-805-1027 for expert help.
Nov 20, 2015 | Computers & Internet
I can't install sp31335 it say some file is missing or corrupt. why is that?
Try redownloading from a different source, google for it and you will get multiple results. Maybe you downloaded a corrupted file, or the download wasn't complete. If it doesn't work, try moving the executable file in c: directory and run it there!
Sep 04, 2011 | HP Copy of sp31335.exe
My computer won't let me download any software. It downloads and then asks me to run it, and I do. Then nothing ever comes up and when i look for the download set up file, it is nowhere to be found??...
If you select 'run' when downloading an executable file (a software installation, for example) the download will be written to a temporary file and then the file will be executed. This means that the installation should have taken place, but the downloaded file is not easily identified and found.
If you are having problems installing some downloaded software you should select 'save as' instead of 'run' when doing the download, and save the file to a known location, e.g. create a folder called 'downloads' in your My Documents folder, or simply save the file to Desktop.
Once you have the downloaded file save you can normally execute it (run installation) by double clicking it.
Mar 06, 2010 | Dell Dimension 3000 PC Desktop
Error Message 'F:\ setup.exe is not a valid win32 application'
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Not clear images while surfing net on my laptop
Try downloading Mozilla Firefox and see if you have the same problem viewing images.
You can get it here: http://www.mozilla.com
I need more information to help you further on this...it may be that you need to install a plugin to view certain images.
The data execution problem could be from corrupted system files on your laptop or from a virus. If you're running Windows XP or Vista, download and run this program:
http://www.malwarebytes.org/
Make sure you let it download updates, then run a full scan.
If that does not resolve your data execution problem, try this tutorial:
http://www.bleepingcomputer.com/forums/topic43051.html
Feb 06, 2009 | HP Compaq Presario v3000z Notebook
Problem during Drive Installation
Hello. It seems like your downloaded file is corrupted. Please try downloading the driver again from the Lenovo Support website. Here is a list of possible drivers for your system. Make sure you select the proper driver and you should be good. Hope this helps.
Jan 25, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Install games on samsung D900, says unsupported file format
find another one ,, that say's for your fone games only.. coz if you dwnload not supported either it not for ur fone , or it was corrupted.
Apr 18, 2008 | Samsung SGH-D900 Cellular Phone
Download files always corrupted
I tried the site you listed & it said Session Closed. Did another search with another search engine & got a hit.
http://www.isd.toshiba.com.au/71/live.dll/topic/content/driver_search_list.jsp?theAction=true&CATOID=-15058&MODE=NPRO&ProductMenu_0=Notebooks&ProductMenu_1=Portege&ProductMenu_2=347755&x=9&y=8
Started the file A100BtoothXP.exe & it uncompressed to a floppy disk I put in my drive. Listed are the names of the files.
BIO0001J.COM 224kb 12/10/2003
CHGBIOSA.EXE 31kb 6/25/2003
CHGFIRMA.EXE 18kb 5/9/2003
EC81NOBB.BIN 128kb 5/27/2003
You might want to try the above link. The only thing I didn't is the flash program.
give it a try rcull999!
Feb 22, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
